Question about Frigidaire FullFGX831C Size Stack Gas Laundry Center
Frigidaire Laundry center blows circuit when w/d run at same time
I have a Frigidaire Laundry Center (from 2005-electric) and my electrical circuit blows every time the washer and dryer are run at the same time. Is this a fuse problem? Can I fix it myself, or should I hire someone? I have replaced a washer boot before but am no laundry appliance expert! Thank you!
  • 9 more comments
  • volkcj May 27, 2009
    I believe it just started happening. The unit has been installed for 3 years and I just learned about the problem 2 months ago. However, it is in a rental unit and it's possible that previous renters didn't let me know that it was occuring.
    Three years ago a washer and dryer were hooked up to the same electrical circuit and the circuit wasn't blowing (2 appliances). Can I check to see if I'm overloading the circuit by checking the circuit breaker? I think the w/d is the only thing on the circuit.
  • volkcj May 28, 2009
    The breaker is two toggles linked together and it is marked as '30'. I flipped the breaker and tried the lights and outlets in the adjacent areas and I don't think anything else is on the w/d circuit.
    As for model numbers, the best I could come up with is that it's a Frigidaire, HD, Ex-Large Capacity, 2 speed combo, 3/4 HP. I hope that's enough. I looked on the back and didn't find the model number (it was a rushed check--I could have missed it).
    I skimmed the warnings on the back and it mentioned that a 30amp circuit is the minimum circuit---so am I ok?
    Please advise...
    Thanks!
  • volkcj Jun 01, 2009
    There is only one cord coming from the back of the unit (it's one big one). I believe there are 2 outlets near the washer and dryer, but only one is in use with the 'large' cord.
    Also, it appears the breaker trips only after the washer is through filling. In other words, the unit can run for several minutes with loads in both the washer and dryer, but then the breaker trips and the loads can't finish.
    Thanks!
  • volkcj Jun 02, 2009
    I'm pretty sure it's not on a GFCI breaker. However, I am going off of memory as the unit is about 45 minutes away from me in a rental property.
    The washer can run through a complete cycle on its own, and the dryer can run through a complete cycle on its own as well. The problem only occurs when both the washer and dryer are run concurrently, and then only after the wash cycle is past the 'fill' stage.
    thanks again!
    This is a good summary. I've been contacting my previous tenants to figure out if this has always been a problem and it's appearing that it may just have been there from day 1. If the unit is overloading my circuit, should I be calling a w/d repairman or an electrician? Thank you so much--this has really helped, by the way. This stuff is not intuitive.
  • Samuel Charles Spriggs May 11, 2010
    Oops, and one more point of clarification: The washer runs by itself thru a complete cycle okay -- is that correct?
    Thanks for the info. I have my analysis written and ready to send to you, but, first, I need one more piece of info.
    Is the 30-amp breaker a GFCI breaker, i.e., does it have a push-to- test button on it?
    Charlie
    Another piece of info I need is does the breaker trip as soon as both units come on, or does it take a while before the breaker trips?
    The breaker you identified is for a 220-volt 30-amp circuit -- this is the standard breaker for a dryer.
    The question would be is the 30 amp requirement you read for both units or for the dryer alone?
    This is a model which fits your description: GLEH1642FS Electric Washer/Dryer Combo
    This one has two cords, one for a 120volt circuit and one for a 220 volt circuit.
    We need this info:
    Are there two outlets behind your unit?
    If there are two outlets, are both supplied by the 220 volt 30 amp breaker you identified? Or, are there two breakers?
    Yes, let's start there. Get the numbers off the breaker and let me know if the breaker has two toggles or one. Then give me the model number(s) of the w/d.
    You might also turn the breaker off and see if anything goes off but the w/d -- that would tell us if their is something else active on the circuit besides the w/d.
    Did this just start happening or is this a new installation?
    If this is a new installation, the problem is an overloaded circuit.
    President:
  • 1,489 Answers
Okay, here's the best I can do from this distance.
The combo unit is on a 30-amp, 220-volt circuit. One cord supplies both washer and dryer.
The breaker does not trip until the washer motor starts running simultaneous with the dryer drying.
My guess is that (if the combo unit is connected correclty to the one supply cord) the dryer motor runs off the 110 volt supplied by the red/white wires & the washer motor runs off the other 110 volt leg, black/white (could be vice-versa, but that's irrelevant).
The dryer heating element runs off the 220 volt supplied by the red/black wires.
There are two most likely causes (but not the only possibilities):
- The breaker is bad -- could just be oxidation on the breaker contacts in the bteaker box -- I havae seen this conditon -- small amounts of oxidation can cause the breaker to overheat and trip -- of course, the more current the load draws the hotter the breaker gets.
- One of the motors (washer or dryer) is beginnig to fail (windings beginning to short) and drawing more than rated current which is overloading the breaker.
Checking thes two theories requires some not-so-standard equipment, and some more-than-handyman expertise. And if neither of these theories pans out, the troubleshooting gets more complicated.
So, to address your original question, "Can I fix it myself, or should I hire someone?, I would say you should hire someone. This wirite-up may give them a head start.
Let me know if you have any questions.
Charlie
P.S.
A third possibility (only possible if this tripping condition ahs existed from the beginnig of the w/d installation) is that the power cord is connected to the unit such that both motors are powered by the same 110 volt leg. Not being there to assess this, I can't say how likely this is, but it's a long shot for sure.
Posted on Jun 02, 2009
  • Samuel Charles Spriggs Jun 03, 2009
    Sorry for the late response. I didn't get your latest post in E-Mail, I just stumbled across it browsing thru the site.
    If this symptom existed when the equipment was new, the problem is almost assuredly with the circuit, and not the equipment.
    I would call and electrician.
    Charlie
  • Samuel Charles Spriggs Aug 18, 2009
    Did you get this problem resolved -- if so, what was the solution?
    Charlie
How do I replace the dryer belt?
Hello Philip, I appreciate your inquiry!
Based off the information you have provided you need help with replacing the belt on your Frigidaire laundry center. In order to access the pulley you would need to disassemble the laundry center. I would recommend seeking assistance from a professional technician for proper disassembly of your laundry center. Incorrect disassembly could cause personal harm or future issues within the laundry center. Best of luck! -Matt
Dec 15, 2015 | Frigidaire FFLE2022MW Electric...
READ FRIGIDAIRE ERROR CODES
Hello Rob Olsen, I appreciate your inquiry!
I understand that you would like to have information upon reading error codes for your Frigidaire laundry center. I was able to locate a manual that has information regarding error codes for your laundry center. I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Nov 09, 2014 | Frigidaire FFLE1011MW White Washer/Dryer...
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
HOW DO I CHANGE THE HEATING ELEMENT IN MY FRIGIDAIRE LAUNDRY CENTER FEX831FS4
Good afternoon Jerry, thank you for your post!
I understand that you are attempting to change the heating element inside your Frigidaire laundry center, FEX831FS4. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Aug 19, 2014 | Frigidaire Washing Machines
Brand new Frigidaire FFLG2022MWO Washer/Dryer Laundry Center. After a wash cycle is finished, the washer will start again after a few minutes. A truly never ending cycle. Please help.
Good Afternoon Mauricio, thank you for your question! Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the appliance. Select a normal cycle and verify if the washer continues to run after ending cycle. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board, timer or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Aug 19, 2013 | Frigidaire FFLE2022MW Electric...
Dryer heat not working
Without knowing your problem, I would guess that the heating element has burned out. This is a common issue with many dryers, regardless of brand.
The hearing element in a clothes dryer is like any other heating element, such as in a space heater, heat gun, or hair dryer. It is basically a continuous coil that is held in place by insulators, usually ceramic.
As the element ages, the coil becomes brittle and can often break. When a breakage occurs, the circuit is no longer complete and will not produce heat.
Replacing one is fairly simple.
  1. The first thing that you should do is unplug your dryer.
  2. Once unplugged, remove the exhaust duct.
  3. Use a screwdriver to remove the electric access panel in at the rear of the dryer.
  4. Locate and remove the heating element.
  5. Inspect the element for a break in the coil. The problem is not always obvious so it may be good to do a continuity test on it.
  6. Replace part if necessary. Elements will usually run $20 or so.
  7. Assemble in reverse order and test.
This website has some really great detailed step by step instructions on replacing a heater element.
Good luck.
Jan 11, 2013 | Frigidaire FFLE2022MW Electric...
Frigidaire Full Size Laundry Center Model LCE-732L
inside the hot water hose is a lint screen, check whether it is blocked
not a solution ~60%
Sep 27, 2008 | Frigidaire Gellery Full Size Electric...
Frigidaire FullFGX831C Size Stack Gas Laundry Center Logo
398 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
