Question about Dell Inspiron 1525 Laptop
Will not charge although it can detect it is plugged in
Hi, when i plug the charger into charge the laptop detcets that it is plugged in however it will not charge it. I have checked the battery stauts and it says it is healty however it is not chrged a single bit so it means i can not work on my laptop when it is not plugged in. It just says that the battery is idle and not charging when it is plugged in although it can detect the fact that it is plugged in. Also i dont konw whether this is any help but it says AC adapter type: unknown device installed. Wheter this menas anything i dont know but i really need to fix it. Thanks Natasha
Hi Natasha,
Unfortunately this is a common problem with current Dell laptops. The notebook checks whether or not you are using an official Dell charger, and if not then it refuses to charge the battery even though the laptop will still work. This means that if you are using a third party charger you will only be able to keep doing what you are doing.
If on the other hand it IS an official Dell adaptor then it is possible that the sensor in the adaptor is faulty. Either way if you want your battery to charge you will need to get the right adaptor from Dell.
I don't like the fact that Dell notebook work this way as there are many perfectly good third party adaptors on the market but at the moment there is no other way around this issue.
All the best
Rob
Posted on May 27, 2009
My dell lattitude 2110 isn't charging while plugged in
It is unfortunate that the computer is not being charged. You may want to try following the below steps which might help:
    (1)Try using a known good AC Adaptor and check if the same issue happens.
    (2)Try wiggling the AC Adaptor cord to see if that makes a difference.
    (3)Check if the AC Adaptor is getting detected (Like a 60W or 90W) in BIOS (F2 at startup).
    (4)Hover the mouse over the Battery on the status bar and see if there is any error message like Not connected or Plugged in not charging, etc appears.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 30, 2014 | Dell Latitude 2110 Notebook
Maybe the connection on your laptop is broken, if so, call an expert cause its a hell of job to fix that.
Maybe its just the charger thats dead, try another one.
Dec 17, 2013 | Dell Inspiron Computers & Internet
96% plugged in, not charging Hi all, my Asus
Laptop battery do have a specific lifespan, specially for older units. Still, you can check that your charger are working properly, using a voltmeter (do check the outer label of the charger for actual voltage output).
You may try to do my Tips on Laptop battery
Good luck
Tedmac
Oct 17, 2013 | ASUS Computers & Internet
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
Every 5 minutes or so it beeps and says it is not charging although the phone is not even plugged into the charger. When you switch it on at first it says it is charging with the bar graph indicating this...
Hi, would have told you too replace two things on the phone,
The charger and the battery.....
But sometimes the charger port where the charger is being inserted into the phone might be faulty too,
So you will need to test for the charger port. Get a new charger and a new battery, and insert the battery and plug in the charger...if nothing happens, that means you will need repair the charging port....
Consult a phone repairer for help...
Hope that helped...
Feb 03, 2011 | Nokia 6110 Cellular Phone
Hello , I have acer aspire one 751, with win
OK, it sounds like the acer aspire one 751 has a bad battery that will need to be replaced. It is not taking a charge, so it is not detected even though it is connected to the laptop. The 'plugged in' message shows that the charger is connected and detected by the computer, but the battery is 'not charging' due to the bad cells.
Good luck on finding a replacement battery.
Dec 18, 2010 | Acer Computers & Internet
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
My Dell Laptop syas that my battery is charged. But when I remove the ac power cord the computer immediately shuts down.
I repair laptops professionally and work on many Dells. Here are the possibilities.
1. The plugin connection where the battery meets the charging contacts in its bay where it seats are malfucntioning and the software is reading it incorrectly. To see if this is so, push the small round black button on the battery next to the 5 little dots at one end. If none of those dots light up green, the battery has no charge and the connection I spoke of above is damaged or malfunctioning beyond where you can see. If all the dots light up green, the battery is likely fine but the laptop can;t connect to its charge at the plugin.
2. The basic software (BIOS) is reading the charger/adapter incorrectly and although saying it is charging or charged, the actual charger is ruined inside in the compartment for charging the battery. Dell chargers can actually be incapable of charging the battery but still run the computer on direct current while plugged in.
3. The battery is no longer able to be charged, but is giving a false reading.
4. The DC Power Jack (into which you plug the charger) is only partially damaged and while able to power the laptop directky, cannot charge the battery. (Check to see if it is loose and woobly when you plug in the charger.
The easiest and least expensive way to troubleshoot and fix this yourself is to start with the charger. They can be had on eBay for about $20. Keep in mind that if no green lights show up on the battery, it might be your first choice and it's about the same price.
I hope I've given you enough info the help you determine your true problem.
Regards,
The Selkie
Aug 29, 2010 | Dell Inspiron 6000 Notebook
Battery is not charging in my acer aspire 5052anwxmi
check connections and also try to get another battery and test for the same
May 30, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 Laptop Logo
376 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
