Question about Itronix GoBook 250 Notebook
IX250 backlight goes out as windows XP boots
The back light on LCD goes out sometimes as windows boots, once it's out it won't come back without reboot. Sometimes coming out of standby will bring it back. The screen is still there just very dark.
Sometimes moving the screen will trip out the backlight
  • darren853 May 28, 2009
    I took the screen apart and put it back together again and now it seems happy. How do I check for / repair broken inverters ?
  • 489 Answers
It looks like LCD inverter(fluerasan) broke down.
Posted on May 28, 2009
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Monitor backlight problem (Dell S2409W)
pa_ma_fi, Have you figured out how to do the flashlight test on you monitor when it's lcd panel turns black or blank n black. No, CCFL back-lit lcd monitors require lots of things to be working all together at once to light up the CCFL tubes. The new style curlie-Q screw-in, energy efficient CFL light bulbs are of the same similar technology and use an "electronic-ballast" circuit to "light-up" the lamp! You will need to check to see if pc is working perfectly with old monitor that you know is good. You should do some free reading here at fixya in my and other fixya ccfl back-lit lcd technicians profiles. ou will also need to visit YOUTUBE for "LCD monitor disassembly" and "LCD monitor repair" videos. May need printed circuit board "switch-mode-power-supply/ ccfl inverter supply " to be repaired If pc software/firmware has been determined not to be causing this on/off/on/off symptom.
12fixlouie
Apr 29, 2010 | Computers & Internet
Black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Jan 09, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
I'va had this pc for about five years. It turns on past booting but once it gets to the windows xp loading screen the Monitor goes blank and shows a no signal message. The tower ( an emachine) still show...
u have problem of disaply scren resolutio for that
when u power up the computer press F8 key then u see safe mode and other menu
then enter in enable vga mode .
then u can change screen resolution to 1024*768 in dispaly property
Apr 23, 2009 | Sony VAIO PCV-V200G PC Desktop
Backlight
If your keyboard glows in the dark,it never lit up.there are two types of keyboards one glows and one actually lights up with a blue back light as an option on the ix250(the bios has the option built in,if it has the keyboard that lights up or not).
Sep 21, 2008 | Itronix GoBook IX250 Notebook
AOPEN LCD monitor
hi
If you switch on your screen it just goes dead again. If this is the case then all you have to do is replace your backlights of your lcd. The backlight are florescent tubes Which are gas filled and they have a lifespan of plus/minus two to five years. Once the gas is depleted the backlights try to go on then switches off
This problem occurs alot on all different lcd screens eg. ibm, gigabye and alot of other name brands and even the cheapies. the backlights come in different lengths so you have to open your screen and remove them carefully so that you dont damage or crack the liquid crystal. i have been repairing lcd screens for a while and this is the problem most of the time.This also affects your power supply as the backlights sometimes arc inside and causes the power supply to act funny the reason for power light flashing
You can order the backlights from RS components. They supply and sell backlights if you wish to do it yourself
Glad to be of any assistance
Jul 08, 2008 | AOpen 19" LCD
Ibm t20 no LCD backlight
while the T20 is on and manifesting the dim display....
1. try to slowly close the lid (but not totally closing it) and then pulling it back to its original position slowly. Tell me if the light goes back.
if by doing that action the backlight lights up, you are most likely faced with a Flex cable problem. You might need to buy this from ebay. (dim display problem in T20 series is very common these days due to wear and tear of the flex cable)
2. Also try to use a pen to turn on and off the limit switch that triggers the backlight. This is located above the keyboard below the lcd. See what happens.
Apr 10, 2008 | IBM ThinkPad T20 2647 Notebook
The back light for the lcd display off
I would bet on a failed FL Inverter board which is the board that runs the backlight.
However, if your LCD is RED before it goes dark your backlight has failed. Given the age of the machine you will probably have to get parts from ebay.
If you can tell me the part number of the machine (on the serial number sticker) - I can look up what inverter or LCD you need - there are several different screens the 6000 series uses that are NOT cross compatible.
Dec 28, 2007 | HP OmniBook 6000 Notebook
ITRONIX GO BOOK IX250
When the computer boots up and says NTLDR missing it can mean several things, but all of the problems are usually attributed to something wrong with the hard drive/filesystem. I assume your notebook was fully functional before. If that is the case: 1.) Your file system may be corrupted / damaged. Try booting from the Windows XP cd. The go to Recovery console.(R) follow the instructions on screen until you reach a prompt (i.e. C:\WINDOWS\) then type "chkdsk c: /r" (without the quotes). This is basically running a disk check with XP builtin utility and the /r is saying to do a full scan and fix problems if encountered. If you get an error that says "unrecoverable errors encountered" then your hard drive is pretty much damaged. If it goes all the way through then there is still some hope. 2.) Your hard drive may be failing and if important data is on there you may need to plug it up in another system to try some data recovery. Well I'll need some more information to make a better analysis! Try the chkdsk and tell me the results! Regards, Babb
Apr 16, 2007 | Itronix (FEX21-192)
Itronix GoBook 250 Notebook Logo
134 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
General Systems...
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
