Question about Porter Cable Cable BN125A Factory - Reconditioned 18 Ga., 1 1/4" Brad Nailer Kit
BN125 Wont fire
Got a BN125A wont fire even after a complete rebuild kit Piston moves freely pin not bent.Just a soft dull thud No action.
  • 79 Answers
Did you rebuild the trigger plunger? Check the plunger on the trigger. Sometimes junk will set up in the seat and cause low flow of air.
Posted on Jan 15, 2010
The trigger plunger answer is a good lead. I found that part number 202 is swollen a bit and it sticks in the nailer body and part number 204 sticks in it. I carefully by hand with my fingers reamed out the hole with a sharp 7/32nd drill bit until part number 204 was no longer sticking. Then I poked the shaft of the drill bit into the hole, gently chucked the drill bit into a drill press and filed the outside of the piston a little bit and then smoothed it with 320 sand paper so it slides in the nailer body hole without sticking. Viola. Nailer works great. Part number 201 fell apart. I replaced it with an 'o' ring for 23 cents. 'O' ring 109 cracked. This one cost 46 cents. As built these two 'o' rings are made of clear plastic. The two 'o' rings 205 that fit on part number 204 are smaller than the smallest 'o' rings at my local hardware store, but they were not bad either. I added a couple of drops of pneumatic tool oil to the parts before reassembly. Total cost of repair was a little time and 69 cents.
Dreasen
Posted on Sep 01, 2010
Why doesn't the trigger do anything on my NS289000 framing nailer?
Nailer not firing is caused by lack of lubrication in the headvalve (lube with white grease) or driver stuck/bent (make sure driver moves freely) or safety foot not depressing the firing pin on the trigger valve all the way in. Easy to check. Remove the trigger to expose the firing pin. With no nails in gun, connect air and depress the firing pin with finger all the way in. If the gun fires, adjust the safety foot. If the gun does not fire, lube headvalve and check driver piston stuck. Good luck
Dec 03, 2013 | Campbell Hausfeld Ns2890 Framing Nailer...
Good Morning, I have a Porter Cable Finish Nailer BN125A. When firing, nail does not go through and piston stays down and compress air goes out the head valve non stop.
Could be very simple problem of headvalve oring coming off or pinched. Remove the head and look at the oring installed on the headvale. Sometimes this oring will fall off the grove. If the oring is off groove and is pinched, you may need to replace with generic oring sold at Lowes (if oring is gold vinyl replace with black rubber from lowes, will work better). If oring is in place, pull out the cylinder and examine the driver for bent blade/broken. If bent, make adjustment or replace as needed. If the driver is in good shape check that the check valve is in the proper place. The check valve is a black rubber band around a series of holes on the outside of the cylinder. Good luck
Jul 12, 2011 | Porter Cable Cable BN125A Factory -...
The Stanley Bostitch stapler will soot a hole inwood but no staple comes out.
Low pressure or worn piston orings will cause missfire due to the piston/driver not returning to top of cylinder and not allowing pins to move into position. Easy test. Remove airline and push driver blade all the way to top with thin metal or plastic. Test fire. If ok and pressure to gun aprox 100psi, install rebuild/oring kit. If driver was already at top position and the next pin is not aligned with path of driver, check rails and pusher for debris or obstruction preventing pins from moving into position.
Jul 10, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
I have a BT200 that will shoot a nail once or twice then will not fire the nail.
It sounds like you have very low air pressure or volume of air. Try increasing the compressor air pressure. If you have an in line filter check that..
Sep 24, 2010 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
I have a Bostitch BT200 that is dry firing. It seems that the "hammer" is not retracting after it fires a nail. I have to push it back manually and even then it seems to dry fire a few times before a nail...
The check seal is what causes the piston to retract. Remove cylinder and examine check seal. It is a small band that covers a series of holes and should fit snuggly around cylinder. Other factors that have effect on piston retraction are, split/cracked cylinder, bent driver and lack of lubrication. This gun is tricky to rebuild. Make shure that all the parts in the head are placed correctly. The kit does contain all the parts that you need. Good luck
Sep 07, 2010 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
MY 18GA nailer will fire but it wont fire the nail.
Usual causes:
Driver doesn't move back far enough. Usual cause of this is inadequate lubrication. Load a bunch of air tool oil, say 20 drops and cycle unit repeatedly.
Wrong type nails.
Nails not properly seated in the tray. Check that they can move freely into the slot/path the driver comes down.
Jammed or broken nail in the path. Disassemble and clean out debris.
Broken nail parts up in the area below the piston. Disassemble and clean out debris
Mar 13, 2010 | Porter Cable Cable BN125A Factory -...
BN125A Nailer will not fire even after rebuild kit
low air pressure may be the cause ,make sure you set the outlet to 70- 90psi
May 27, 2009 | Porter Cable Cable Brad Nailer and...
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Apr 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Bn125 brad nailer is jammed
I've had to remove the plate over the "firing pin" a couple of times (the allen wrenches come with the gun) to release it. Mine was caused by a bent pin, that happened when I hit the hose and knocked it off the bench.
When I finally replaced it (CPO/Porter Cable), it's been fine ever since.
Mar 31, 2009 | Porter Cable-Cable No.BN125A...
Senco SFN1 wont work
I have worked on many sfn1 with the problem that you describe. Here are a few things to check. Driver/piston too tight or too loose in cylinder or bent. It should be relatively easy to move the driver piston up/down the cylinder. Usually it should hold it's own weight and not drop down the cylinder. There is a washer that should be at the bottom of the gun under the bumper (washer part# bf0070). This washer must not be worn to the point that too much air will leak past or missing. Finally there is an oring that controlls return of piston (part # lb0077). Pull out the cylinder and find it located on the outer part of the cylinder close to bottom. Clean the port holes under the oring and make sure that the oring fits snuggly. Do not use oil in this gun. Oil will swell the rubber parts. I use silicone lube available form Lowes in the plumbing department. The grease is used to lube faucet orings. Good luck with your repair and email if you have questions.
Mar 16, 2009 | Senco SNS41 16Ga Stapler 1" 2"
Porter Cable Cable BN125A Factory - Reconditioned 18 Ga., 1 1/4" Brad Nailer Kit Logo
397 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
