Question about Porter Cable Cable Brad Nailer and Compressor Combo Kit CFBN200A
BN125A Nailer will not fire even after rebuild kit
Porter cable Brad nailer BN125A after installing a rebuild kit still does not fire. Just a dull thud Pistin moves freely pin is not bent . What is the cause
    Sergeant:
    Champion:
  • 226 Answers
Low air pressure may be the cause ,make sure you set the outlet to 70- 90psi
Posted on May 27, 2009
I have a Porter Cable brad nailer BN125A, at 125 PSI and depth adjustement turned to the deepest drive setting, the brad does not set flush with the surface. Problem?
A brad nailer in good working order, set to the deepest setting and using 125psi should almost shoot the brad through the wood. If you have been oiling the gun properly (three to four drops at he beginning of your work session and again in the afternoon if under constant use) then you probably have some worn o-rings inside the gun. Porter Cable makes a driver maintenance kit (PN1001 60062) for your gun that will make it work like new.
Oct 04, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Porter cable bn200 nailer
Get a gasket kit---sounds like top seal around barrel
Feb 21, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
Air is escaping from the top of the bn125a brad nailer. It won't fire nails.
it sounds like you have a damaged o ring/seal that requires maintenance. You can go to Dewaltservicenet.com and download a breakdown for this tool and also order parts for it. When reinstalling new o rings don't forget to put a little bit of grease on them so they don't roll or pinch. Let me know if you need more help
Nov 13, 2009 | Porter Cable-Cable No.BN125A...
How do you install nose cushion (part#894742) on brad nailer(model# bn125a)?
You should be able to just push it onto the the safety latch part 417 on the breakdown. The open part faces forward and you push the latch into the opening in the back of the nose cushion. It will then lock into place by the tabs on the latch.
Sep 10, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
BN125 Wont fire
Did you rebuild the trigger plunger? Check the plunger on the trigger. Sometimes junk will set up in the seat and cause low flow of air.
May 27, 2009 | Porter Cable Cable BN125A Factory -...
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Apr 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Bn125 brad nailer is jammed
I've had to remove the plate over the "firing pin" a couple of times (the allen wrenches come with the gun) to release it. Mine was caused by a bent pin, that happened when I hit the hose and knocked it off the bench.
When I finally replaced it (CPO/Porter Cable), it's been fine ever since.
Mar 31, 2009 | Porter Cable-Cable No.BN125A...
Porter Cable BN125A won't set nails below surface
Not sure about the seal, but I do know the pressure has to stay up for this nailer to be effective. Try oiling the gun to free up the mechanics and don't use old nails.
Jan 23, 2009 | Porter Cable Cable BN125A Factory -...
Porter Cable Cable Brad Nailer and Compressor Combo Kit CFBN200A Logo
625 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
