Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Icemaker Arm stuck in up position
The arm on my icemaker is stuck in the 'up' position and it won't budge. Its not making ice. Any suggestions?
    President:
  • 1,136 Answers
Hi, Check and see if the finger sweep has ice jamming it so that it can't finish it's rotation. This is a come problem. You might have to remove the ice maker to see what is blocking it. Usually two screws on top and one underneath the ice maker.
Please let me know if i can assist you further.
Vic
Posted on May 27, 2009
Ice maker subzero 690 stuck won't make ice because i think the plastic flap that rises when the ice bucket fills is stuck and won't come down to turn on the water
There is a screw sticking out from the right side of the freezer wall that has a grey plastic spacer around it that acts as a stopper for the ice level arm. I have seen the ice level arm get stuck on top of this stopper before somehow. you just have to carefully bend the level arm around it and move it below the grey plastic stopper. If it is not stuck above that but the arm still will not come down, then the only other solution is likely a new icemaker, as the arm is geared internally to the icemaker to rise and fall as the ice is made.
Sep 26, 2014 | Sub-Zero 690 Side by Side Refrigerator
LG LRSC 26920tt won't make ice
In order to determine the problem you must check a few things:
1) Is there water in the ice tray? If not. verify the saddle valve is turned on, check the connection on the water valve, verify that there are no kinks in the inlet hose, and check he water filter to see if it is clogged.
2) Is the temperature correct? Make sure the fans are working properly and air is flowing. Verify the the frig and freezer are at the correct temperature and make sure the ice maker compartment door is sealing shut.
If these things check out ok, run an ice maker test. Make sure the ejector arm and feeler arm are in their original positions before beginning. If they are not:
1. Turn off icemaker and wait 5sec.
2. Turn on icemaker.
3. Wait until feeler arm and ejector are back to original positions.
To begin the icemaker test: Press and hold the test button on the icemaker for 5 seconds. If the LED, feeler arm and or ejector does not return to to their original positions the problem is with the ice maker.
The ice maker part number for your model is 5989JA0002G
Oct 14, 2013 | LG LRSC-26922 Side by Side Refrigerator
Need to know how to turn on ice maker in whirlpool gz25fsrxyy2
Should be a wire feeler arm that runs front to back on that icemaker. If it is stuck in the up position---the icemaker is OFF. It should be hanging downward to be in the ON position. If up---just gentley pull it down until it is moving freely. As the ice bin fill with cubes that arm should move up and down with the icemaker. Once the cube level is high enough for the feeler arm to be held in the up position it will stop making ice until you use enough cubes for the arm to fall again.
Sep 26, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
Freezer is trying to make ice cubes but unable. I can hear it tripping. Should arm be in up or down position?
Hello the arm should be in the down position in order for the ice maker to try and start makeing ice cubes. when you stated you can hear it tripping what can you hear tripping can you see the icemaker arms spining. Sometimes i find it is best to remove the icemaker from the unit 2 1/4' screws located on top and one located on the bottom and then take the hole icemaker and run it under hot water for a couple minutes this causes any parts on the icemaker that are froozen up to become defrosted and sometimes it will go back into proper functioning order as well. If you have any further questions message me back Thanks
Rick
p.s if arm was in up position this would shut the icemaker off and it would not attempt to make ice any further
Jun 29, 2011 | Amana Refrigerators
Our GE side by side fridge isn't making ice. The arm in the ice maker starting clicking in the middle of the night and my husband just went into the freezer and held the arm up for a few seconds. The...
It sounds like you have a bad icemaker. Usually when the arm is clicking its the gears that are stripped out. Feel in the icemaker if theres cubes frozen in there then you know the icemaker is definitely bad. With the arm in the up position it will not make cubes at all that is the off position for the icemaker. Hope this helps _MJ_
Apr 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Icemaker won't make ice
Try using a hair dryer.Arm may be froze up.mitchjl_1692
May 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Icemaker makes tons of ice and it spills all over the floor
The icemaker should have a thin metal arm that turns it off when the arm is raised, and on when the arm is lowered. This is so when the tub of ice gets full, the cubes push the arm up, and the icemaker is turned off to keep from making excess ice.
When I had the overflowing ice, I checked my icemaker and found that the arm had fallen off (and thus the icemaker won't know when to stop making ice). I found the arm and stuck it back on, and all was well. It may be a bit tricky, and it might take some ingenuity to keep the arm from falling back off.
I hope this helps!
Sep 29, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
1,252 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
