Question about Coleman Mach III Air Conditioner
Fan wobbles on coleman MACH3
Need directions on how to remove and replace fan and motor.unit is 20 yrs old
  • steve
    steve May 11, 2010
    Buy a new AC.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
What is the model number of your current air conditioner? You will usually have to remove the upper shroud, evaporator housing and condenser housing to get all of this out. With that removed, the fan motor should have three or four studs holding it to the plate. Remove the screws from the plate and the whole assembly will lift out.
Posted on Jun 30, 2009
Remove rv fan motor
Probably not. You need to get a puller on the fan blades though
Jun 03, 2013 | Coleman Heating & Cooling
20 yrs old nutone fan light it only pulls down about inch i need to change buld
There are spring clips that hold the grille in place. The clips can be compressed and detached to permit complete removal to gain access
Feb 08, 2013 | Broan-NuTone Broan 110 CFM Premium Bath...
How many watts is a coleman super mach
Specifications are listed below:
http://www.mycaravanparts.com.au/products/appliances/air-conditioning/coleman-mach3.aspx
Bear in mind, this A/C unit is made for Recreational Vehicles with a Heavy Duty Battery to power such devices for a short time and external power supply for extensive use. The watts listed in the specifications refers to cooling and heating power in watts, British Thermal Units (BTUs) was the old measurement term. Do not confuse these cooling and heating watts with the amount of electrical power consumption in watts. The two are unrelated. Power for this RV A/C unit comes from a battery or external RV connection point. Hopes this helps you.
Aug 27, 2012 | Coleman Mach III Air Conditioner
I have a Mach3 unit with 1 capacitor 35uf 370 VAC and a fan capacitor, unit trips breaker after cooling RV when system starts up again, shouldn't there be a run, start,fan capacitor? only have 2...
You need to check the Amp draw at start up of the compressor. Also if you have a meter that can check the compressor capacitor, it needs to be checked. If the capacitor is ok and the compressor starts at a higher Amp draw than the rating on the capacitor, you will need a start capacitor.
Jun 04, 2011 | Coleman Mach III Air Conditioner
Coleman mach3 wireing diagram diagram
Hi, Yes, but you need to know which wires do not need to be hooked up...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 16, 2010 | Coleman Mach III Air Conditioner
I have a Coleman A/C unit Model # BRCS0481BD and I need to replace the condenser fan motor. It doesn't look complicated but I was wandering can anyone post a how to tutorial. Thanks in advance, ...
Disconnect power to the unit. Remove the fan blade. Remove motor from mounting bracket. When replacing the motor, replace the run capacitor too.
Mar 10, 2010 | Heating & Cooling
The outer fan dont work. where can i get a replacement ?
Check at your local computer/ Hobby Electronics parts store.
Take the fan out of the unit and to the store with you, that way they can match it to one they may have in stock.
Sep 14, 2009 | Coleman Electric Cooler 40 Beverage Cooler
My Mach3 coleman ac compressor hums but wont start. trips breaker. I replaced the start capacitor with a hard start. still wont run?
unfortunaletly the hartd start is a "last resort" and you will probably need to replace the compressor/unit... (however I have had luck physically jarring the compressor during the instant I applied power to the compressor.. sounds silly, but I have had it work more than once..) hope this helps
Aug 15, 2009 | Heating & Cooling
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Replacement fan motor for coleman mach3..need wiring diagrm
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Apr 14, 2009 | Coleman Mach III Air Conditioner
Coleman Mach III Air Conditioner Logo
165 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
