Question about Dryers
Not heating up
We have a Kenmore 80 series gas dryer. Just the last 2 times I have used it, it turns on , but is not heating up. Is this possibly something that we can fix ourselves. If so, How?
  • kb615 May 27, 2009
    This is a kenmore gas dryer 80 series. I will have to look to see if there is a model Number.
    President:
  • 1,136 Answers
Hi, check the fuse first. This is the most common model. If this is not your model, please get me the model #. Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If the fuse is ok, let me know so I can tell you how to test the ignitor.
Normal 0
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on May 27, 2009
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Series 80 gas dryer. Turn on and flame only lasts few mins.
Intermittent contact inside one of the gas valve coils. Replace. Part number 279834.
You can order them at AP Wagner. Use coupon "New10" for 10% off
Oct 16, 2009 | Kenmore 75944 Gas Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Heat does not stay on
Check the high limit thermostat. You can check it using a multimeter or ohmmeter. If bad, replace it. Hope this helped.
Jul 18, 2009 | Kenmore 800 7983 Dryer
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Kenmore gas dryer series 80 not heating up--dryer revolves but no heat--guessing it's the ignitor--can't access-no lower panel to open tomroske@msn.com
small plug left side bottom remove it this will allow you to see if ignitor is coming on if it is suspect the coils on gas valve or no gas to dryer if no glow possible bad thermal fuse remove back small white object on blower housing ..if no lower panel ..remove 2 screws under filter pop top 2 clips 1 each side about 2-3 inches from end..2 screws 5/16 1 each side upper corners remove lift front off
Jun 27, 2008 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
145 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
