Question about Powermax 2" Intake 6.5 HP OHV 158 GPM Gas Powered Water Pump
Powermax 2" water pump vs Honda 2" water pump
I am irrigating an orchard using water from a drainage ditch. I want a good reliable pump. I can purchase a Powermax XP652wp water pump for $240 or a Honda WB20X for $384. Both are 2" pumps and will do the job. I assume that Honda is more reliable but is it worth the $144 difference? I have never heard of Powermax pumps and I don't know anything about them.
Thanks,
Leon
    President:
  • 1,185 Answers
You need to look at the engine
Cheaper units use a Briggs & Stratton unit which is noisy and tends to wear
Honda uses their own and normally runs sweeter and longer without any drama.
Check for oil consumption on both units again the Honda seems to fare better
One drawback is that the Honda unit is more of an attraction to thieves so if it is left unattended it may take a walk
Posted on May 27, 2009
Muddy wTer filling basement vedroom via window well and dirt
Try a pump to make what comes in go out to a drain .inside house or outside.ormaybe.build a drainage flow outside like a cement line or ditch with rocks as a filter
Jul 07, 2014 | Plumbing
Do I need a pressure tank with a Pentair Water 3/4Hp Pres Wtr System 3075Ss Utility Pumps?
Depends on your application. If you are using it to provide water to a residence or other on/off use, you need a pressure tank and a pressure switch to control it. If you are filling a open air tank, no pressure tank needed. If you are just pumping water out of a well and directly to an ditch type irrigation system no tank needed.
Aug 09, 2012 | Pentair Water 3/4Hp Pres Wtr System 3075Ss...
Where can I get a replacement ceramic seal for my powermax water pump xp650wp ?
contact the manufacturer on the net at their spares department or go to an irrigation and pump specialist shop and they will get/have one for you.
Jul 09, 2011 | Powermax XP650WP Portable 3' Water Pump...
The well pump is running, but no water is supplied to thr irrigation lines. once I put water in the pump housing by removing the pump guage the pump pumps water through the irrigation lines. when it shuts...
Sounds like you have an air leak. First check your fittings, next carefully run water over the pump seals (avoid getting water on the motor or you'll hurt yourself and the pump if not worse) the pump will prime if the leaking seal is covered with water. Take your time and be careful and it should only be a matter of a loose fitting or simple seal swap.
Mar 08, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Powermax water pump shuts off after 5 min or more
Either the coil/HEI module is bad or your on/off switch(kill switch) is bad. Check those first.
May 19, 2009 | Powermax XP650WP Portable 3' Water Pump...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
I have a 1/2 hp pump which I use to pump lake water to my irrigation system. The pump takes too long to turn on when the spicket is opened and sometimes too long to shut off when the water spicket is...
when using the spicket you use less flow than your irrigation system so a delay in the pump coming on is normal...otherwise if you are having the same problem when the irrigation is running..a pressure switch adjustment may be necessary...please follow the manufacturer instructions for your pressure switch.
Mar 31, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Powermax 2" Intake 6.5 HP OHV 158 GPM Gas Powered Water Pump Logo
439 people viewed this question
Top Powermax Garden Experts
Dennis Key
Dennis Key
john h
Are you a Powermax Garden Expert? Answer questions, earn points and help others
