Question about ViewSonic VX2433WM 23.6" Monitor
No sound when using HDMI cable but I do have sound if using DVI
When I use my DVI port on my Viewsonic Monitor my sound works. When I switch to the HDMI port my monitor sound doesn't work.
    Scholar:
  • 34 Answers
Is your computer configured to send sound through the HDMI cable as its output device? This might be a setting within your sound card properties.
Posted on May 27, 2009
If you need it to work in Windows 7, do the following:
  1. Go to the Control Panel (Start Bulb->Control Panel)
  2. When the control panel appears, select Sound.
  3. When the Sound window appears, select the Playback tab.
  4. Finally, right click on anything that says HDMI Output, and select "Set as Default Device"
  5. To see if it is working, right click on the device again and select Test, or pop-in some tunes.
Posted on May 14, 2010
I want to connect my Xbox 360 to my aoc f22+ monitor so I bought a hdmi to d-sub cable to plug the Xbox into the monitor as it didn't have a hdmi input. The screen just shows a blank image and the only...
You need a HDMI to DI cable not HDMI to d-sub cable. The sellers that are selling that cable do not tell you that it will only work with special video cards that output analog to the HDMI connector. HDMI is digital and so is DVI so they will adapt to each other. Keep in mind that this is for video only, sound will not work on the monitor because the DVI port does not support sound. You will need to add a set of speakers to the Xbox
Aug 27, 2012 | Computers & Internet
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
I have my PS3 hooked to the HDMI port, but the monitor won't switch inputs to the HDMI port. If I have something plugged into the dvi port it works fine, but I currently need only the HDMI port, and do...
There are a varity of HDMI cables, ensure that your version is supported also using the input touch "button" to change the input through VGA, DVI and HDMI.
damnor01
Nov 22, 2010 | Acer H233H bmid Monitor
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
I have a Viewsonic Monitor vs11349 and it will not connect with my acer PC...it comes up "no display". The monitor has a DVI that I need to use a VGA adapter. SHouldn't it work?
Did you try the setting on the monitor to use the DVI port instead of VGA port. Should also try it on another PC to narrow down the problem. Try VGA to VGA cable also.
Apr 06, 2010 | ViewSonic VX2245WM LCD Monitor
Viewsonic vx2265wm screen with the PS3
I have the same problem! I'm using the HDMI-DVI cable that came with the monitor because it lacks an actual HDMI port. DVI is the big port with the grid, right? Anyways, is there a way to put monitor Drivers on the PS3? The monitor doesn't have a menu so I can't manually resize. Also, LittleBigPlanet automatically splits like 720p whenever I play it.
Mar 21, 2010 | Video Game Consoles & Games
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
DVI-HDMI work but there is no sound
DVI input has no sound as normal you can use a RCA connection to get sound from the freeview box
Apr 21, 2017 | ViewSonic N3000W 30 in. HD-Ready LCD...
Monitor says No signal digital
Is ether the monitor or video card uses both DVI or VGA port. There may be a switch on the graphic card that changes it from DVI to VGA, often outside the card.
Also is the computer monitor set to the right setting if it can use both VGA and DVI, if using DVI (of any type) it need to switch to digital, and if using VGA it need to be set to analog. This may be a physical switch or using the settings button. (see manual how to change them)
PS: VGA port is a blue D shaped port with 15 pin holes, and DVI is a white rectangle port with one port being a line.
Mar 17, 2009 | ViewSonic VG2030wm LCD Monitor
Acer H213H No sound
Dude, the hdmi is just for the video signal, you'll have to use a separate audio cable to get sound from the integrated speakers.
Jan 02, 2009 | Computers & Internet
Open Questions:
ViewSonic VX2433WM 23.6" Monitor Logo
1,155 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
