LOAD WONT FINISH KEEPS SAYING DC
I HAVE A MAGTAG NEPTUNE WASHER AND IT KEEPS SAYING ON THE SCREEN OF MACHINE DC. I KEEP ADJUSTING LOAD BUT THE LOAD WILL STILL NOT FINISH ITS CYCLE
  • Samuel Charles Spriggs May 11, 2010
    What does the owner's manual reveal about this error code?
  • 15,935 Answers
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch.
The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
I keep getting error code dc and it wont spin
Somewhere on this forum I have a response to DC or UC unbalance errors and the fix. It's hard to find my past post on this forum.
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support posted in the sticky at that site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
Apr 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer wont finish cycle and display reads "LR"
Hello todd.... This is a common problem with the neptune. It means that the machine needs a new motor and a new motor control board kit. If you are under warranty do a repair. If not, get an estimate before you go ahead and repair it. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The washer wont drain and finish a cycle
Is the wash tub banging aroun in Spin Cycle and failing with a unbalance code of dC or uC?
What is the model number?
May 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune TL when it gets down to 12 minutes left it starts flashing dc and wont finish the cycle, what is wrong?
You could have a Clutch malfunction if the machine is a FAV6800A or FAV9800A. If that is you r machine type see this post. Clutch Fix
Post back of you have questions.....Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Keeps flashing DC will not finish cycle?
Hello jernlyn,
If your machine is A FAV6800A or FAV9800A most times this is a Clutch malfunction. Dose a Spin Only Cycle complete with no clothes in the wash Basket?
If your machine is one of the above I can help you DIY the repair. See this Clutch Fix Post . Most DIY folks can perform and I will help you with any questions or concerns. If you decide to DIY what are the 1st two digits of your serial number? They will 10 thru 17.....Rich
Feb 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont Finish Spinning stops and Flashed DC
If the machine type is a FAV6800A/FAV9800A see this Clutch repair post if you want to DIY. You will find links to the Service Manual and parts info if needed.
You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of max Wash Tub movement and the Control Board shuts the Spin Cycle down……..so thebTDS is working as designed.
The machine will make several attempts to redistribute the load before error code generation failing with dC or uC error codes.
Post back if you have questions any DIY'er with basic skill sets can do the Cluch maintenance/repair.....Rich
Jan 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
