Question about Roper RAS6233KQ Top Load Washer
Water trickles slowly into the machine.
Water comes in the machine in a trickle
  • dotti_terhun May 27, 2009
    Thanks so much for the advice - I tried it and it worked.This is a wonderful web site.
    President:
  • 1,185 Answers
Turn off the water.
Switch on the machine and let it try to start filling, that will take the mains pressure off the hose, switch off the machine
Take off the hose at the washer end and check to see how much dirt there is in the small filter inside the inlet solenoid
Most of them pull out for cleaning , be gentle they are nearly all made of plastc and can crack
Posted on May 27, 2009
My ice maker has a slow leak so it eventually turns the cubes into one giant cube. Do you know how I could fix this??
The reason the fill tube is freezing is because the tube that connects to it and connects to the water inlet valve is seeping water slowly. It's just enough water to trickle into that tube at the top and since its so cold that little trickle freezes,then the next trickle freezes and so on and so on. After enough small drops of water freeze the entire tube is frozen. To stop that replace the water inlet valve the small diameter tube connects to.
Reply back with model# and i will give you the part #
Gene
Aug 21, 2011 | Admiral 26 cu. ft. Side-By-Side...
FH FAULT CODE COMES UP ONLY AT START OF RINSE CYCLE. WATER JUST TRICKLES IN VERY SLOWLY. WATER FLOW INTO MACHINE IN WASH CYCLE IS FINE. ANY IDEAS? WHIRLPOOL MODEL GHW9250LW
Most probable case of a flow meter defect
You can access this part by taking to or three screws off the top panel in the back
Part is attached nere the water valve
White round thingy
Jun 17, 2011 | Washing Machines
Hot water entering machine is only a trickle. It
Check the filter trap on the back of the washer where the hot water fill hose connects to the inlet valve, you wil have to shut the hot water valve off first, then remove the hose at the washer and inspect the little filter screen thats in the valve where the hose screws onto the washer, it probably has trapped enough sediment to restrict the flow of hot water into the washer.
Good Luck !
Mar 14, 2010 | Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water trickles very slowly hot water has plenty of pressure it is a maytag pav2300 how can i fix this problem
1. Check cold water hose for obstructions
2. Check cold water spigot for proper water volume
3. Cold water electronic valve may be failing, easy to replace
Apr 15, 2009 | Maytag PAV2300 Top Load Washer
Kenmore washer. At rinse cycle only, water fills very slowly.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2009 | Kenmore Washing Machines
Water is filling slowly
8. re-try.
Mar 24, 2009 | Kenmore Washing Machines
Water only trickling out or not coming out at all
your solenoid valve needs to be replaced this is the valve where youre hoses conects on thankls from gilles
Mar 15, 2009 | Washing Machines
Roper RAS6233KQ Top Load Washer Logo
70 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
