Has a bowed effect and no convergence option in settings.
Hd52w67 has a bowed effect and I don't see the conversion option on my menu.
  • 8,617 Answers
Replace the FL231, DL231 and CP230 you can get the replacement parts with step by step instructions on how to do the reppair at the following link. The parts are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
Posted on May 27, 2009
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
Have the HD52w67 rca. Have a 3d effect. know we have to adjust the lamps. we go to menu but we have no auto convergence. What can we do now?
Is there a manual convergence setting in the menu? if so try to adjust the level 1, 2, and 3 settings. If not try to clean the lenses with qtips and alchohol.
Mar 07, 2010 | RCA HD52W59 HDTV Projection Television
Pic has a big bow in it and the colors don,tline up, went and had a new convergence board installed and still have the same problem
Is the convergence option still listed under the on screen menu's setting options or has it disappeared? Let me know and will assist you with the problem.
Dec 14, 2009 | RCA HD52W59 HDTV Projection Television
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
RCA big Screen
Convegence problems are so common on these sets. The bowing picture indicates to me that you have lost complete convergence. Now the first question that i always ask is do you have the convergence option under setup in the customer menu. If you do not then i say congratulations this is a simple inexpensive repair if you can solder a component. this is known as the fl231 problem and i have a article relating to the problem under my profile in tips and tricks section. that goes into detail on how to repair this problem.. If you do have the convergence option then we wil have to go further into troubleshooting. there are three possible cuircits that effect this.. if you do have convergence. try autoconvergence option and see how far it gets. let me know how it goess.
Oct 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problems with 52in HDTV
NO this is a condition known as convergence problems. first question in menu then go to setup and see if the option of convergence is in the menu. is the picture bowed in from the top and bottom. do you have the option of autoconvergence. does it work and how far does it get. there is a common problem with these sets. and may be a simple fix if you can solder a part. so let me know and we will continue to troubleshoot.
Oct 29, 2008 | RCA D52W19 52" Rear Projection Television
Convergence
Okay, usually the parts that go bad to make the convergence option drop from the menu are the following. Fusible Link (FL1231) Diode (DP1231) and capacitor ( C1230) the numbers in parenthesis are the actual component locations on the board. These items fail causing the set to think its a direct view set instead of a projection unit.
Apr 13, 2008 | Televison & Video
I cannot adjust my convergence
This is a very common problem with the ITC222 chassis. If you cannot access the Convergence Menu (either in Customer or Service Menu), the FL231 fusible link is the culprit. More than likely that is blown, which will cause the Convergence Menu to disappear, "bowing" picture, convergence to be off, and will run as  "tube CRT" mode.
It is also important to check the Flyback transformer and the solder connections below it. If you have a bad connection (i.e. cracked solder), FL231 will blow again and experience the same problems.
Aug 21, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Electro Med Services...
