Acer Aspire 4520 14.1-inch Notebook PC
Problem for Acer Aspire 4520 14.1-inch Notebook PC
How to reformat the hard disk of laptop w/o recovery dics?
By jedrick017 on May 27, 2009
I got a friend with Acer Aspire 4520 and he ask me to reformat the harddisk and to retain its genuine OS which is Window Vista, the problemwas he lost the Recovery Disc. is there any way to reformat the diskand retain its genuine OS?
Best Solution
posted on May 27, 2009
Very Helpful)
flubbard
Rank: Wiz
Rating: 93%, 17 votes
Reformatting will wipe the drive clean and you will need to reinstall windows, either from the rescue CD or from other media. You may be able to contact Acer and order a replacement CD and install it using the OEM license originally sold with your machine.
If it is merely a problem that programs are not running correctly or that something has corrupted the computer, see if there is a good restore point that you can use from "System Restore." This may allow you to fix the problem and remove the offending program without having to go through the trouble of reformatting and finding the replacement disk.
Finally, since you say that it is Vista, it should be a relatively new machine and it may have a restore partition instead of a rescue disk. If this is the case, there should be a utility in your programs from acer that will allow you to restore the computer to its original form. This will typically reboot the computer and handle the format / reinstall for you. It's possible your friend can't find the disk because he didn't have one.
Just a heads up, typically you can not use a rescue disk from another machine (different make or model) as it will check the hardware configuration before installing the software to make sure it matches the machine the disk shipped with. It is not serial number specific though.
Hope this helps!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
dkspex
Rank: Guru
Rating: 85%, 65 votes
if you had a friend/colleague who has vista then you could use their disc as the cd key on the laptop will work. Other than that i'm afraid you may be unable to reformat without a vista disc.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
Murphybanton
Rank: Guru
Rating: 90%, 2277 votes
No except you contact an Acer service centre in your location.
Comments:
May 27, 2009
- No except you contact an Acer service centre in your location.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 4520 14.1-inch
Questions and Unsolved Problems for Acer Aspire 4520 14.1-inch
Do you recommend Acer Aspire 4520 14.1-inch Notebook PC ?
Answer
Answer
I've got a NV52, running windows 7. The card reader installed drivers after I inserted it, but I... (More)
Answer
My hp pavilion dv8000's screen is black.
Answer
Acer Netbook Aspire One touchpad not working
Answer
my laptop's touchpad scroll on keyboard is not working, what to do?
Answer
stuck when boot on level 67. Dell L 610
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 4520 14.1-inch...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
