Question about Air Tools & Compressors
Troy Bulilt Pressure washer with no pressure
Troy Build 2500 PSI pressure washer. The unit will operate when cold.
The Thermal Relirf Valve kicks on after about 10 minutes of use. When this occurrs the pump provides no spray rendering the machine useless. Water streams out of the thermal releaf valve.
Sounds like the spring that hold the relief ball is to soft and when heated it releases..if it has a manual adjustment on it you might try to add a few turns to increase the spring pressure also check and make sure the pump has the proper level of oil in it ..if it is low in oil it will run extremely hot and the relief spring will fail
Posted on May 27, 2009
On my brute 2500 psi pressure washer when I let go of the trigger it kills the motor. I changed the unloader valve and still does it . Any suggestions? Thanks
Excessive pressure can stall out a motor. Try reducing by adjusting unloader valve. Clockwise turn will increase pressure, counter clockwise turn will reduce.
Oct 30, 2016 | Garden
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
The pressure washer starts but no water will pass through. The model is RX2600.
Common problem. The water admitance valve is stuck in the bore. The valve lets in more water when pressure drops and when wand is closed the pressure builds and the incoming water is blocked. Remove the valve spool and clean the bore with crocus cloth on a dowel rod. Replace the O Rings and lube with plumber's grease and re-assemble. Often you can buy an O Ring kit for the unit. Deposits build up and stick the valve spool at the high pressure end. The valve is usually crossways to the shaft and right where the water input is connected.
Jun 29, 2011 | Honda 2500 PSI Gas Pressure Washer
I have a honda excel 2500 psi , where would the pressure relief valve be located?
Many of the excel units don't come with a pressure relief valve but instead a thermal relief valve, it really depends on the model number of the pressure washer. You should only replace the thermal relief valve if it is leaking.
Sep 06, 2010 | Honda Karcher G2400HH-R Pressure Washer
My Troy Built pressure washer shuts down when I turn on the water. Is the pressure cut off valve that might be frozen?
Hold the trigger of the pressure nozzle open. Turn on the water . Wait to see water coming out of the pressure wand.Then try and start the engine. They can get air locked.
Feb 12, 2010 | Karcher 2500 PSI Pressure Washer
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
The small black valve is called a thermal relief valve. If it is open you will have no pressure. If the water is getting hot enough to pop that valve, there might be internal problems with the pump.
Nov 22, 2009 | Karcher 2500 PSI Pressure Washer
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Apr 05, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Air Tools & Compressors Logo
221 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
