Question about Brother MFC-5440CN All-In-One InkJet Printer
Unable to clean-need trouble shooting guide
Just purchased a brother fax, scanner, copier model # MFC5440CNZ but didnt come with user guide. The unit will not operate because the error message unable to clean is coming up. Need help it says unable to clean. I tried unplugging it still getting message. What should I do ?
I am having usual problem of unable to clean (Brother MFC-5440CN). I have looked for any strange object but can't find any. Could this be amechanical problem and what is solution?
Posted on Jun 21, 2009
  • 489 Answers
User's manual can be found here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5440CN_5840CN_EN_108.PDF
The error message itself is due to either a mechanical problem with the device or a foreign object in the printer preventing it from functioning (torn paper, clip, etc). Open up the cover and check for anything that looks like it doesn't belong there.
Posted on May 27, 2009
    Problem Solver:
  • 17 Answers
The manual can be found here (its a PDF).
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
My printer say "Unable to clean See trouble
you can download the user guide in english language from this link: http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000222/Mini2LowBase_UkEngUsr.pdf for the error enable to claen see page 11-4
Dec 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Clean unable 46, See Trouble shooting and routine
When you are doing cleaning process many times, You Purge Countergets overflown, You need to be reset the same by some technical rest code required. By pressing - menu -start - menu , Just go in reset counte and reset the same
May 12, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Just got a brother mfc 5840 cn from a yard sale and plugged it in and have a unable to clean. Trouble shooting and routine maintenance chapter in the users manual. It didnt come with one?
Are you saying it has an ERROR message "unable to clean..."?
if so, it just may need new ink cartridges.
Aug 14, 2009 | Office Equipment & Supplies
Trouble shooting, unable to clean
hi friend,
Brother MFC-5440CN
http://www.brother-usa.com/MFC/ModelDeta…
user guide,
http://welcome.solutions.brother.com/bsc…
pdf
http://welcome.solutions.brother.com/BSC…
"Unable" to Clean pg 11-4
try starting by unplugging power and usb for 30 ~60 seconds to cancel out possibility of software conflict glitch ,
possibility of fax in progress,
and also try re-seating ink cartridge,
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Brother Office Equipment & Supplies
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Cleaning troubleshoot needed
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model. This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue. 1. Check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. 2. If the error continues to appear, the machine may have a mechanical problem. If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Jul 28, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
487 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
