Question about KONFTEL 100 Audio Conference
Starting a yamaha kt 100 go kart engine
Embarking on a go kart project never had one before making a starter need to know ir it has to turn clockwise or anti clockwise to start the enjine
Just bought this go kart , the guy said it was a yamaha kt 100 2t 2 stoke but i have no clue about this motor , is it a good one
Posted on Mar 13, 2010
  • jeff4fros534 Feb 23, 2011
    you need to know a lot this engine is very hard to work on and run, for ex. if you start it too lean it can freeze the engine while you try and tune it..... but with the right tools and info is possible, do not make starter, buy one used on ebay. the starter is very complex and has a one-way bearing so when motor starts will not chew up allen head tip. Think of this engine as a very large and powerful weedeater that will take off with or without you...get a kill switch installed!!
Yamaha starting problems
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
How To Star Starter Clutch Replacement Sample
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Yamaha
Jul 05, 2014 | 2005 Yamaha V Star Classic
My starter just spins on my r6
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. starter spinning but engine not cranking
Inside look of starter spinning but not engaging
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Sep 01, 2013 | Yamaha YZF-R6 Motorcycles
My 2006 r6 starter relay clicks like a dead battery and my bike wont start and my starter just spins my motor wont turn
http://www.r1-forum.com/forums
Won start just clicks but can push start Jumping relay doesn start it
What is the correct idle adjustment on a yamaha rt 100 dirtbike
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb. The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have wonderful a day.
Yamaha RT100 Carb Rebuild Cleaning
2 stroke Carb Tuning Idle Adjustment Fix Your Dirt Bike com
DOWNLOAD Yamaha RT100 RT 100 90 00 Service Repair Workshop Manual Download... $9
http://mybikemanuals.com/yamaha/yamaha-rt-owners-manuals
Jun 13, 2012 | Yamaha Motorcycles
How to adjust the idle of yamaha rs 100
Hi, Andy you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yammy100 com View topic How to set your rxs 100 airscrew tickover
Idle mixture adjustment air or fuel screw adjustment
Yamaha RS 100 Manuals Support and Troubleshooting
http://www.rssailing.com/uploads/files/092012/5050a4cc6c14bf66a00000a0/original/RS100_owners_manual_v2.pdf?1347462348
May 20, 2012 | Yamaha Motorcycles
2005 Yamaha 1100 starter runs but does not turn engine
Starter Clutch Problem
Yamaha XVS1100 DragStar Starter Clutch Replacement Part 1
Yamaha XVS1100 Service Manual
YAMAHA XVS1100 Owner Manual
May 17, 2012 | 2005 Yamaha V Star 1100 Silverado
1986 Yamaha pw80 carb settings
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
Yamaha Carb Tuning
Life On 2 Wheels
YAMAHA PW80 Owner Service Manual
YAMAHA PW80 Owner Manual
Feb 24, 2012 | Yamaha PW 80 Motorcycles
ENGINE RUNS BUT NO POWER
IT COULD BE MORE THAN ONE THING,,, FIRST CHECK COMPRESSION, IF IT HAS LESS THAT 80 lbs THAT IT,,, PUT IN NEW RIGS,, IF IT HAS COMPRESSION, THE TAIL PIPE COULD BE STOPED UP,, IF NOT,,, 2 STROKE ENGINE'S HAVR REEVE PLATES, THEY COULD BE BAD,, REPLACE THEM,,, THE CARBERATOR COULD BE IT IF ALL THE OTHER THINGS ARE GOOD, MY BEST GUSS IS,,,,,,IT NEEDS RINGS,, LARRYFRANKUM6780@SBCGLOBAL.NET LET ME KNOW,,,
Dec 10, 2008 | KONFTEL 100 Audio Conference
Yamaha kt100 kart
I've never seen a KT100 before, but i've worked with similar engines.
The fuel isn't gravity fed. It uses a pulse pump system using diaphragms in the carburettor to sort of "**** and blow" the fuel using pressure impulses and valves to stop the fuel going backwards.
The first place you should look is if there is a short pipe from the crankcase to the carb so that the pressure pulses from the case can move the diaphragms. You should be able to see this from some pics on google images. If thats all ok, you should check if the carb is perfectly clean. If its still giving you problems, change the diaphragms in the carb. You should be able to get a replacement rebuild kit from a dealer.
Jun 09, 2008 | KONFTEL 100 Audio Conference
KONFTEL 100 Audio Conference Logo
2,906 people viewed this question
Top KONFTEL Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a KONFTEL Lands Phone Expert? Answer questions, earn points and help others
