Question about Compaq Presario 5000 PC Desktop
Pc tower motherboard upgrade
What new motherboards can i put in the presario 7000 series pc case ?
  • arsenal43rd May 28, 2009
    i looked inside the case there are 5 pci slots and one agp slot , a sound card, modem, tnt graphics card , 10/100mb internet and 2 free slots the board itself measured 24 cm by 31 cm with 6 or 7 screws between 5/ 1/2 inches to 6 inch apart from eachother it seems like a full but could be a large looking mid
  • 86 Answers
You can put in any new micro-atx motherboard no problem. I can be 100% sure if the case is Atx full size- best way to check is to see how many pci expansion slots are available at the back of the case. Any Atx case can hold micro-atx mobo's but a micro atx case wont hold atx mobo.
Posted on May 27, 2009
  • Dale
    Dale May 27, 2009
    just to let you no, in my solution it is meant to say "I cant be sure if the case is Atx full size"
  • Dale
    Dale May 29, 2009
    full ATX motherboards
    have a maximum
    size of 12"x9.6", and Mini ATX boards have maximum dimensions of
    11.2"x8.2".
    going by these dimensions the motherboard you have is an ATX motherboard and you also have 5 pci slots. I'd say you definately have an ATX motherboard. Here's more info to backup my claim:
    "Most modern ATX motherboards have five or more PCI or PCI-Express expansion slots, while microATX boards typically have only four (four being the maximum permitted by the specification)."
I want to change out/upgrade the motherboard. What will fit into my existing tower?
Buy a new towercase that is compatible with the new motherboard. You may need a more powerful power supply which should come with a new tower case but check it does.
It will be hard to assess if the previous tower has a powerful enough compatible power supply and what size motherboard it is rated to hold..
Oct 19, 2015 | Gateway Computers & Internet
Supported Motherboard Models for upgrade on Compaq Presario 5186 Desktop Computer?
Form factor is your main concern. This dictates screw holes and case alignment. ATX standard is the most common over counter mobo.
Aug 28, 2012 | Compaq Presario 5186 (108830-034) PC...
From: weinleinm@gmail.com I was given a COMPAQ PRESARIO some years ago and I would like to upgrade motherboard, trade in or donate it. Can the motherboard be upgrade for more speed and WI_FI...
Laptops are the toughest to boost performance wise. More memory, bigger hard drive are common fixes. Scour HPs website for your specific model & maybe serial # will fine tune its parts list. Then go to HP's webstore for new part pricing. Get HP's part number for the CD or DVD if they made one for your motherboard, case & plugin arrangement.. or, replace the CD drive if you want to & then go to your favorite Electronics store & buy an external DVD Burner for $50. The only way to add software to the new NetBooks. -DellTech1
Jan 08, 2011 | Compaq Presario 1620, 1621, 1622 Series...
Help to ID motherboard from Compaq 5000 series
there is a compaq part number printed on all HP/compaq components. if you search for that in google. you can find replacement parts
Dec 09, 2009 | Compaq Presario 5000 PC Desktop
I bought the hp slimline s3707c a few months ago and I love it! But due to me being a huge gamer I needed to upgrade my Vid Card. The new card doesn't fit in the tower so I bought a bigger tower and was...
My best suggestion is to get a professional installer to do it for you.
If you want to do it yourself.
  1. take the top of (make sure to ground yourself) and DONT work on carpet if possible. Static is bad!
  2. the HP is nice in the way that it has sliding internal features. So some of the chasis will slide out of the way. Take advantage of this.
  3. BEFORE you take ANYTHING APART make sure the mounting screws of the motherboard line up with the mounting area of your newly bought CASE. Also, make sure output on powersupply on new case comparable to your existing one, and that connector wll fit your MotherBoard.
  4. disconnect all power supply wires
  5. take out Power supply which will give you more room
  6. disconnect ribbon cables (or SATA), remove them.
  7. unscrew mounting screws on motherboard and put it in your new case. Make sure MotherBoard does NOT ground to your case (IE it should not wiggle around) and be put in securely
  8. remove peripherals from your old case and put in your new case (HDD, CDROM, etc.)
  9. connect power supply cables, then ribbon cables (or SATA if so)
  10. Put case together and connect wires in back (Monitor, keboard, etc.)
  11. Your are done, Congratulations!
Nov 09, 2009 | Computers & Internet
Compaq Presario 7000 PC Desktop
Don't do it!!! If you are going to do such an upgrade, buy a PC Case. By the way, you can buy bare bones at Systemax for about $200 and include almost everything needed but the Windows.
May 27, 2009 | Compaq Presario 7000Z PC Desktop
Upgrade compaq
you can, go to www.tigerdirect.com.
ensure your purchase is compatible with the chipset in your pc
Nov 11, 2007 | Compaq Presario 1200,1600, Series CD...
Compaq presario 5151 desktop cdrom drive removal
Take off the other side panel and you should be able to get at the screws. Also, Compaq has a handy step-by step guide with animations to help. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07164&lc=en&cc=us&dlc=en&product=93108&lang=en
Aug 29, 2007 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
276 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
