Question about Kenmore 73952 Gas Dryer
Dryer Won't Start
Kenmore 90 Series, Model # 97591220.. Turn Timer Hear ticking sound, push start nothing happens, Took off kick plate and cleared all lint, took off flex vent seems to be clear, reset breaker, tried different outlet, if you turn timer to off hear a loud click (like start button resetting for next use), turn timer again, hear ticking, push in start get click but nothing. Set timer and it will run out (as if dryer was working) Dryer is probably about 10yrs old (came with house) would like to fix if anyone has idea's. Please help
  • twawrzyniak May 28, 2009
    tried that, door switch is good, tested thermal fuse with ohm meter, all contacts seem good and clear, no wires burnt, i have no idea, it looks like there should be nopthing wrong with it, but it still will not fire, could it be a bad timer box??? sat and just held down start and spun the timer box back and forth until i got mad, then it started working. turned the box to off opend the door to make surew it was getting warm, it was, turned the timer back on and now nothing again, now it wont start. Any other thoughts?
    afraid you were going to say that. Any idea where i could get a replacement? or would i be better off buying a new dryer. Is this something i could take apart a look at?
    Scholar:
  • 85 Answers
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
  • shinn8
    shinn8 May 28, 2009
    That Sounds like a short in the timer. That is very rare for one to do that but from what you describe thats the problem
  • shinn8
    shinn8 May 29, 2009
    You can check on Appliance Parts Pros website
    www.appliancepartspros.com
    Get a price on it and determine if you want to spend that much on it.
    They are fairly expensive
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and...
i had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Jan 03, 2011 | Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
My Kenmore Dryer stops before the time I set is up.
Sounds like the operating thermastat may be bad letting it get too hot and causing the motor breaker to kick out . When it cools it will start again. Check all thermastats.
Mar 12, 2010 | Kenmore Dryers
Kenmore dryer
Do you hear the timer ticking?
Make sure there is 220 volts present at the terminal where the cord hooks to the dryer.
Inspect the wires for loose or burned.
Check continuity on the door switch.
Check continuity on the start switch.
Mar 11, 2009 | Kenmore Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Kenmore 90 series won't start timer ticks
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73952 Gas Dryer Logo
855 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
