Question about Indesit W 123 Front Load Washer
SPARKING FROM UNDERNEATH WASHING MACHINE, CHECKED BRUSHES IN MOTOR , THEY APPEAR TO BE OK.
  • Indesit Master
  • 3,463 Answers
The brushes may look o/k , but you can still get excessive sparking from armature if there is a short on it
This being the case, then only solution is to replace the complete motor,
Please rate my advice.
Thanks.
Posted on May 27, 2009
Why is my washing machine sparking underneath
if this happens during spin or when motor turning its probably from the motor, if this is the case you will need a new motor, if lucky may just need new brushes, motors are around 30 - 40 pounds, brushes about 5 pounds from parts supplier.
Oct 24, 2014 | Washing Machines
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Jan 06, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
Hotpoint Ultima WT721 F 08 fault code
Try the brushes first. I'm guessing the carbon deposits on the floor are from the brushes.
Nov 16, 2013 | Washing Machines
Bosch wvf2000 sparks when washing
stop using the machine. call someone to look at it. sounds like a motor problem / short. it could be that your brushes are worn right out. if you get into the motor itself you can check this. use a multi meter to check the winding resistances are all equal before wasting time dismantling the motor.
Nov 09, 2013 | Washing Machines
Hotpoint WD40 not entering spin cycle? Drains ok. I've checked the belt, that seems ok. There appears to be black soot?? underneath the machine as if something has blown??
Sounds like need new motor brush kit cost of parts varies from around 6/18 GBP, quite simple to fit see the espares website
Oct 28, 2013 | Washing Machines
My service washing machine is sparking underneath what could it be
Loose wire or motor brushes may be on their way out or motor going faulty.
Check the easiest and cheapest first as a new motor can be pricey.
Dec 27, 2012 | Indesit Washing Machines
SPARKS ARE COMING FROM UNDERNEATH MY HOTPOINT WASHING MACHINE WHEN DRUM IS IN ACTION
hi dont worry the carbon brushes in the motor need replacing soon it will stop spinning if you remove them you will notice that the carbon brush is very short should be an inch long they are easy to change thankyou good luck
Jan 18, 2011 | Hotpoint Washing Machines
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Motor not running in Asko 10504 washing machine
The motor might have burned out. Another possibility would be a partially fried control board.
Jan 17, 2009 | Asko Washing Machines
Indesit W 123 Front Load Washer Logo
673 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
