Question about Olympia 1500.1C HS Shredder
Pulsing clicking sound when paper is inserted
The shredder specifically being used:
Olympia
TYPE: 679-1CF
S/N: 84879. 044254
Model: 1500.1C - KTR2712 - BM35.977-0019
Issue:
Our office has been using this shredder for a few years and never had any major problems until now. Every time we insert a paper into the machine a loud clicking sound comes from the inside. There are no visual obstructions on top or underneath. It still shreds but it sounds like something is loose internally.
  • 18 Answers
SOURCE: My shredder stop shredding. has paper caught in itposted
If your equipment makes abnormal noise when you try to switch on again then gear problem is confirmed else the change over switch should be defective or there may be a open circuit in the change over switch connection I shall advice you to call the service engineer for fixing the problem else take safty pecaution to attempt repairs
Posted on Sep 02, 2007
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
  • 35 Answers
SOURCE: Olympia shredder 1280.6
On this model, make sure the hopper is all the way in. If it is, remove paper hopper and check to make sure the hopper is not broken. There is an electromagnetic switch in the front and the hopper has a magnet built in to it. run a stick magnet across the right underside and front to see if it extinguishes the light. If not, then the board is bad.
Posted on Feb 23, 2009
goalie39
  • 469 Answers
SOURCE: Olympia Shredder Jammed and not working
likely a spacer has broken, if you can see the underside of the cutting heads you will see a spacer or two hanging out, If this is the case the heads will have to be bebuilt or replaced.
Posted on Apr 15, 2009
danforddan1
  • 192 Answers
SOURCE: shredder won't shred
They may be a compression switch on the lip where it sets on the bucket. This it to prevent it from running while its off its buckette. If this is not all the way in it wont run. Look for that clean any safty switch or buttons you find.
Slap it with your tax booklet and call me in the morning. Good luck DFD
Posted on Apr 16, 2009
How to find switch settings in ceiling fan to match remote
Most people use a paper shredder, not a fan. Try posting in the correct area. Fantastic question but I have no idea what your asking. Make model etc helps a lot.
Nov 22, 2014 | Olympia Office Equipment & Supplies
How do you oil this shredder?
You did not give the model ## of your shredder. Most all shredders are OILED from the top slot where you you insert the paper to be shredded. DO NOT USE WD-40 OR ANY OTHER BRAND TYPE OIL. Use oil made for shredders or you can use SILCONE type oil. Wd Corp & Liquid Wrench companies make this type of oil. I have used it for more than 10 years in my shredder and I have not had a problem. The cutters work great.
Make sure BEFORE you oil that you make sure all shredded paper is removed from the cutters.
Spray from one side to the other(paper feeding slot) Run the shredder forward and backwards (WITHOUT PAPER) for about 5 seconds. This should be sufficient.
Sep 02, 2014 | Fellowes Office Equipment & Supplies
Only goes in reverse
Lube might not be necessary. Unplug the shredder from the outlet. Lift it off the shredded paper bin and turn it over. It is very possible that you have a jam. If this is the case, remove as much paper as you can making sure that you don't use anything that could do damage to the cutter'shredder blades. Once you have removed as much paper as possible, place the shredder back on the bin making sure that it is aligned properly. One way of making sure is to check for any space between the shredder and bin. If you do have space make sure that you replaced the shredder correctly on the bin; you may have to turn it around 180 degrees. When you get the shredder properly aligned, use the switch (DO NOT USE PAPER AT THIS TIME) to switch the shredder from Forward (shredding) to Reverse. You may have to do this a couple of times so be patient. At this point the shredder should be working in both directions. If so, move the switch to Auto or the center position and try a SINGLE sheet of paper. If it shreds that piece of paper, then you have fixed it. Be sure not to insert more paper than the shredder is rated for. Also, unless it specifically states that it can handle staples, credit cards, etc. do NOT let any of these items run through your shredder.
If none of the above works, buy a new one - :)
Jan 10, 2014 | Techko SH1524CP Shredder
Our Olympia paper shredder forward switch does not work but the reverse does.
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck..
Apr 15, 2011 | Olympia Office Equipment & Supplies
The shredder jammed (too much paper) then stopped and won't shred. It makes a noise, but when I insert paper, it won't shred. Is there a reset button? I picked paper out of the blades with a pair of...
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Mar 07, 2009 | OfficeMax 0M96431 Shredder
Mar 06, 2009 | Olympia - 1452C CROSS CUT OFFICE SHREDDER
Shredder Errors before Paper Touches Blades
When the paper shreds it pulls both the blades inward. Reverse spins them outward.
There must be something too large between the blades because it can be pushed up just not pulled down.
Has a staple or paperclip been inserted into the machine?
Try one of these two things:
When you're vacuuming the machine, hold the reverse button in and see if that helps.
Unplug it, take out all loose pieces like the bag liner, tape the door closed, get another individual to help you flip it upsidedown and GENTLY tap the machine to break free any obstructions.
Hopefully one of these solutions will work for you.
Jan 15, 2009 | Olympia 1500.1C HS Shredder
Jun 12, 2008 | Olympia 1280.6 Shredder
Paper shredder
sounds like you probally have a broken gear on the drive portion of your shredder can't be more specific because I only have info on Fellowes brand shredders. You may have to contact manufacturer for more info.
Jan 26, 2008 | Office Equipment & Supplies
Olympia 1500.1C HS Shredder Logo
44 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
