I have a 24" acer monitor that I was setting the display settings via computer, wwhen a box appeared in middle of screen(rest is black) and it read"input signal out of range, please selcet 1920x1200x 60hz for best performance. The problem is that now nothing works on monitor. I have tuned it off, along with computer, thinking it may reset, checke the cables, reattached them, tried different monitor(which is working fine) I am at a loss what to do. Help!!
  • 24 Answers
Your screen resolution is set incorrectly, boot up in either safe mode or VGA mode and change it from there.
Posted on May 27, 2009
    Scholar:
  • 88 Answers
You might have set the dispay settings to high or too fast for the monitor! You should change the Display settings to match (if you still have the old monitor)! Otherwise, try set it in Safe Mode.
The speed of refreshing should not go over the specified 60Hz. You might had it set to above 70Hz at other resolution. Should update Display card driver and/or software too.
  • Patrick Kam May 27, 2009
    Once you have boot into Safe Mode and if the Display Settings cannot be changed, try registry hack:
    1. Open Registry Editor, (Start->Run..., regedit [Enter])
    2. Navigate to this "folder": HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Hardware Profiles\0001\System\CurrentControlSet\Control\VIDEO
    3. Expand the Folders until you see 4 digit numbered folders (you may have a few of these)
    4. Click on them and look for the binary key "DefaultSettings.VRefresh" on the right panel
    5. Double click the key and set it to value "3c" (Hexadecimal) or "60" in Decimal, click OK to apply
    6. Alternatively you can change the resolutions as well:
      DefaultSettings.XResolution = 780 (Hexadecimal) or 1920 (Decimal)
      DefaultSettings.YResolution = 4b0 (Hexadecimal) or 1200 (Decimal)
    7. Close Registry Editor and reboot PC. Hopefully you should be able to use it right away.
    If you think your display card is not able to produce such high resolution, try 1024x768 and ramp up from "Display Settings" under normal boot mode.
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
The computer boots but there's no display
check the display properties for dual monitor settings in
display properties>settings> check all options
I think it is set for external display u change to dual display. then both displays can work. or there is some display symbol of some function key. check that and press
Jun 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have tried all option on the Acer screen so the
The resolution is done at the PC video output setting, not at the monitor, you should set the PC video resolution to be at monitor native resolution: 1920 X 1200 @60Hz This will give the correct aspect ratio of your display.
Mar 26, 2010 | Acer X243W 24" TFT wide format screen 24...
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Acer AL511
Hi...there,
I thinks your OSD Setting time set to high... Open on screen display on your monitor, go to OSD Settings and look for OSD hold time and setting to 10 seconds. If that doesn't work...reset to Factory Resettings.
Jan 12, 2009 | Acer AL511 15" Flat Panel LCD Monitor
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
Monitor problems
Try setting your resolution lower via the control panel; it appears the resolution picked by Windows is beyond the monitor's capabilities.
Dec 13, 2008 | LG Computers & Internet
Horizontal display size adjustment
Make sure the video resolution is set to 1024x768.
Right click on a blank area on your desktop. click properties>settings.
Oct 03, 2008 | Acer AL1511 15" LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
