Question about Kenmore Elite Oasis 27052 Top Load Washer
I have a 2007 Kenmore Oasis washer. When doing a loa of laundry, about a quart or less of water leaks from somewhere under the maching. It is not from attachments for water in or out. It seems to be m
I have a 2007 Kenmore Oasis washer. When doing a loa of laundry, about a quart or less of water leaks from somewhere under the maching. It is not from attachments for water in or out. It seems to be most prevelant when on the drain cycle.
  • 15,935 Answers
Most likely a cracked hose or loose clamp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I would like to know if the kenmore oasis washing maching tub is to have liquid in it for balancing purposes
See the following Whirlpool Service Manual for their Cabrio washer. The Kenmore Oasis is basically the same machine.
Yes it does have a balancing (actually 2) ring(s).
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Apr 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My washer started leaking, we checked all
Three times we have had problems with our drain pump and coins making it through. Once the coins made a hole in the intake hose. The last two times the coins went through the pump and the impact cracked the pump housing causing a flood in our laundry room. The sevrvice man advised there was no solution to the coin problem other than making sure you check your pockets thoroughly.
Mar 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
KENMORE WASHING,wATER IS LEAKING FROM THE BOTTOM NOT THE HOSES
Possible circulation or drain pump leaking or associated hoses. See page 11 Oasis Tech Sheet
Jan 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis 2709 water level problem
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Jan 09, 2010 | Kenmore 4292x Front Load Washer
Leaking water from the front of the washer checked the hoses and they are not leaking
If this is a top load washer the problem is usually the pump. If you can tilt the washer up at the front and support with two pieces of 2x4. Shine a light under the maching and take a mirror to observe. Fill the washer 1/2 full of water and advance the time into the spin cycle. Observe under the maching to see where it is leaking. The pump is located at the front of the washer. If the pump is leaking, replace the pump.
Dec 29, 2009 | Kenmore Washing Machines
Brand new Whirlpool Oasis leaking all over floor
Take the back off & make sure the out let hose is still on your pump.
Dec 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Thick Gear-like oil leaking from the bottom somewhere
looks like your washer is developing a leak from the seals in the drum thus allowing some water to seep into the bearings get it checked before the bearings run out completely
Jul 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water hose leaks at the washer connection
Did you change the rubber washers in the hose? or did you use the old ones there should be a rubber washer inside the front of the hose.
Jan 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
395 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
