Question about DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad
Recharge air condition
I have a heat pump central air unit by "Trane". The pipe going into the house has ice forming on it. Vary little air is coming out of the vents in the house. I'm told that it may need to be recharged (Freon or equiv.).My question is can I charge the unit myself and how?
  • Samuel Charles Spriggs May 11, 2010
    First, are you saying there is no air blowing through the system ducting in the house? if the inside fan is not running this would have nothing to do with refrigerant.
    Secondly, aren't the refrigerant lines insulated?
    Thirdly, I would not suggest trying to recharge the unit yourself for a host of reasons.
  • 83 Answers
if little air is coming out there maybe a problem in the blower or filters. But if there is air and its not that cold or warm then its a refrigerant problem or the lack of.
A simple check for lack of refrigerant would be to look at the refrigerant pipes on your rooftop unit and see if its freezing.
Altghough you can charge the unit by yourself, I would suggest to have it done by technicians because you would need to know how much refrigerant to put in there; what's the correct pressure; system integrity. You'll get your money's worth since it would not just be recharging but also system check.
I hope this helps.
Posted on May 27, 2009
    Problem Solver:
  • 6 Answers
If you have solid ice build up on the "big" pipe (suction line) and very little air coming out of the vents, it's more an air flow problem; Inside fan not working, dirty coil inside (evaporator) or block filter. Open the cabinet inside and take a look there first.
This should be easy to fix; if the filter is dirty, replace it. should be done every month anyway.
If the coil is dirty, depending on access there's a 50/50 chance you can clean it you're self. If you can't you will have to call a technician who will pump all the freon in the outside unit, disconnect the coil, clean it & reinstall it, that should run you $200 to $300
You say there is a little air coming out so the fan is probably working, but if not, you will to find out why the fan is not running. That's electrical, could as easy as the thermostat is not turning the fan on to replacing the fan it self.
It is possible to have frost coming back if you are undercharge (low on freon) But the conditions have to be just right. A Journeyman mechanical carrying an EPA license working under A license contractor is the minimum you need to be able to buy freon since the 90's. that's legal of coarse.
To charge a system you also need a set of gauges and you need to know the working pressure of the system depending of the freon inside.
I think you only have a block filter or a dirty evaporator, possibly a collapse duct.
Good luck
Benge
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
My trane xe 1000 central air conditioning unit turns on and the fan os working, but no air is coming into tue house. The lines get ice on them outside. I left it off all night with no change in status
If you left it off all night and no air is coming out of supply registers then the blower motor is not running. If the system is getting frost on the suction line(the big copper line coming out of the outside condensing unit with rubber insulation on it) within minutes of turning the system on then that will confirm that the blower motor is not running properly.
Unless you are very experienced in working on air conditioning, i would call a professional to do the repair.
If the motor has to be replaced its takes an experienced technician to do it correctly.
It could simply be the run capacitor on the blower motor.
This is probably going to be a 5 mfd capacitor.
Turn off all power to air handler, remove service panel, set your multi-meter to mfd (microfarads),
place the leads on the connections on top of the capacitors securely for 5 seconds. You should read about 4.8 to 5, if not the capacitor is bad.
There are other possible problems that could cause your symptoms, but ultimately your blower fan is not blowing air.
Sep 01, 2011 | Heating & Cooling
Ice is forming on the pipe
Hello, ice will form on the suction line for one of two raesons, either low airflow or a low refrigerant charge. Start by checking the filter to make sure it is clean, then check the blower wheel and make sure it is clean. If the unit is clean then the unitnis low on refrigerant and will require a hvac tech to come out and recharge the unit.
Jul 09, 2011 | Heating & Cooling
WATER LEAKING
Water should come out of the back of a wind unit when it is humid out, usually a drain hole. If water is leaking inside from a window unit, check that the outside drail hole is not clogged or maybe it is not tilted downward enough outside (Usually a very slight tilt down toward the outside to help the water drasin out the back outside). Also, if you have excess water forming, you may need to clean the coil. For central air units water should be drippng outside the home via a pipe or tubing and if the drain tube or pipe is clogged with scum that forms inside the pipe water will back up and overflow in the house near the heater/air conditioning unit. Also, some units have a pump to pump the water out and it may not be working.
Aug 07, 2010 | Heating & Cooling
I have a 20 year old Trane heat pump. Outside
Yes, you will want to put the unit into cooling mode to help assistance with the ice melt.
If you can, block off the outdoor coil or disconnect the outdoor fan motor. This will assist in raising the discharge pressure and temperature and thus, it will melt the ice quicker.
Or, if you have the capability, you can take a garden hose around to the unit hooked into hot water and melt the ice that way.
If your control board is messed up, why aren't you replacing it?
Jan 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
My Trane air conditioner is not blowing cold air
there could be a few things low on freon will cause the coil to ice up and no air can get through,breaker or switch to the blower unit in the house is off belt broke or the moter let go
Jul 05, 2009 | Ruud Central System Air Conditioner
TRANE 1984 Home A/C Where are How to Clean Coils inside House
the best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Jul 02, 2009 | Heating & Cooling
The unit is leaking a lot of water from the bottom. What should I do? I do not see a drip pan and am not using the dehumidifier. It is vented to the outside but vent is raised up and not even with the...
All air conditioning units remove moister from the air.Which is good,it helps the moister on your skin evaporate faster,and helps cool you down.If its a central heat/cooling unit it should have some form of drain pipe to carry this moister away from the unit.Usually a white pvc tubing. Sometimes these become clogged with dirt,or even believe it not algae.If there is no drain someone didn't do the job right.(clean the gunk out of the pipe,or replace the tubing). If your talking about a window unit the unit will drain out the back of the unit,but the air conditioner has to be tilted in such a way that any water inside the unit will flow toward the back of the unit. (simply lower the outside end of the unit a little lower than the side stuck in the window).I see you mentioned a vent so you are probably talking about a air handling unit in your home.The vent should just be for fresh air.If you have a very tight house an air handling unit will be designed to bring fresh air into the house(to keep your air fresh).That is usually its only function.There should also be a small drain pipe leaving the unit somewhere.Some modern units even have a back up drain if the first clogs,and maybe even a signal that tells you the first pipe is clogged.
Jun 24, 2009 | Continental CEPAC1062-1 Portable 9800 BTU...
DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad Logo
665 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
