Question about Kitchen Ranges
My KEBC107KBSO KitchenAid single electric oven has recently started making a loud continuous clicking type sound when it is turned on. This sound continues even after turning it off until the oven is cool again.
  • hometown645 May 28, 2009
    I posted in my problem that the noise continued EVEN after the oven was turned off. It makes this noise from the time the oven is turned on until the oven is turned off and cool again. Maybe I should not have said "clicking" noise. It is a loud continuous noise. It is so loud, you can hear it in the next room. Your answer stated that the noise you were speaking of stopped when the oven heated up and the metal expanded. NOT my problem. Do you have any other ideas? Thanks. Doris
  • 3,741 Answers
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model numberhere.
this will help you.
you can get the parts at
www.repairclinic.com
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 28, 2009
    Brigadier General:
  • 3,917 Answers
Okay found out what might make the noise. There is a fan which makes noise..turns out it was the stainless door cover vibrating when the oven is pre heating. This also explains why it might die away as it heated up since the metal expanded enough to silence it. I loosened and retightend the screws and the noise was gone. In my original post I mentioned the vent in between the oven door and control panel. When I was holding my hand on the vent it was also touching the door, which made the noise go away. I am sure the range will be silent.
Thank You
Posted on May 27, 2009
I have a kitchenaid oven that suddenly developed a very strong "plastic"/electric fire type smell the last time we used it. We turned it off and it went away eventually and we didn't think about it. I...
Sounds like it will not explode, but it surely may start a fire somewhere.
I should recommend you to have someone unplug it ( if it can be unplugged) or turn off the circuit breaker if it is "hardwired " into the house or apartment.
Please have it checked by an expert before you try to use it again.
Be blessed.
May 20, 2014 | KitchenAid Kitchen Ranges
Oven started making a clicking noise after I started the self-cleaning process. Continued until "F8" flashed next to the clock. When canceled was pressed, the clicking started again. As a...
F8 means a fault on the door locking switch.
Something may be preventing the door lock from operating properly.
The solution is to have the door lock switch and wiring checked over.
Dec 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
FAN NOISE in convection mode, as in a loud whirring sound, suggesting a problem with the fan. Any one else experiencing this?
FAN NOISE IS NORMAL BUT IF ITS SQUEELING THERE IS A PROBLEM WITH THE COOLING FAN. YOU DO HAVVE TO REMOVE THE OVEN FROM THE WALL TO REPLACE.
Jan 24, 2010 | KitchenAid KEBC107 Electric Single Oven
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
There was a poof sound in the oven and the breaker jumped. I put the breaker back on and it jumped again,I put the breaker on and the top element work but the bottom element ..nothing. I think the baking...
Very likely - yes. Turn the breaker off first (there is usually always power to one of the terminals of the element). Remove the element and check for continuity. No continuity - replace.
Oct 13, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Aug 25, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid kebs177 continues to beep, no display, clock works onl
Hi. try to reset this unit by killing the power or unplugging the cord for 5 minutes. this will reset the control. if the control continues to beep after you reset, this will confirm control failure. you will need to replace the control board in this case.
May 22, 2009 | KitchenAid KEBS177 Electric Single Oven
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
