Question about Car Audio & Video
Subwoofer buldging out problem
My husband and his friend installed stereo ,amp,subwoofer last year. Two weeks ago all of the sudden I noticed I wasn't thumpin'. I made sure wires didn't get hit and pushed off (kinda wiggled them too) fuses aren't blown . It worked for a few minutes and then quit again and still not working and no one has time to look at it. Is there something I can actually do fix it? I have 2 12" subs in the back. I noticed after a friend drove the car that all bass stopped. The fuse on the mtx amp was blown. I replaced it and one sub works just fine and the other seems to buldge out when on. Like its pushing out. When it goes off it goes back. I disconnected it for now. Is it blown?
  • D?rk R?bb?
    D?rk R?bb? May 27, 2009
    thx for the reply. i think in the car the wires to the amp were sticking out a little and they touched sometimes. the wiring is good for the leads cause it was working before, i have cables that have pos/neg printed on them for just that reason. Is it possible the 1 channel on the amp is reversed polarity?
  • D?rk R?bb?
    Scholar:
  • 33 Answers
When speakers are wired in the wrong way the will do the "pushing out" you're describing. Basically the polarities have been reversed and if kept like this over a period of time will blow the speaker. Best thing to do is to disconnect the power by the negative on the amp and take out the fuse from the power supply. Check the wires running from the amp to the subs, negative to negative and positive to positive. I know it sounds basic but many people do mix it up! I would also check to see what channels the subs have been wired into?
Best way is to have one sub from channel 1 and the other sub from channel 2 for example. Or if its a bridged 4 channel amp, have 1 sub running from channel 1&2, and the second sub running from channel 3&4 still making sure of the polarities. Again this all depending what kind of amp and sub you have.
For example;
A 4 channel (bridged) 1000W amp. 250W max per channel or 500W per 2 channels! So if you have 2 500W subs, by connecting one to a single channel will decrease subs ability due to the lack of power supplied. However by combining 2 channels you optimize the output!
Once you know all your wiring from your amp to subs are ok/good connections/good wires etc you shouldnt have to "wiggle the wires" to get it to work as this is just a bad connection. Also ensure that no 2 wires are touching. Make sure that the master volume on the amp is turned down. You dont need this to be on loud at all, in fact far from it or you'll risk damaging both the amp and subs!
Hope this helps!
Posted on May 27, 2009
  • AnIdea
    AnIdea May 27, 2009
    Normally its stated on the amp itself with a negative/positive, sometimes through use it does get rubbed off. The polarities are always the same on every channel i.e
    Channel 1 + - Channel 2 + -
    One channel will never be different from the others.
    Hope this helps
What is draining my car battery?
sounds like perhaps it is time to purchase a newer car and let that one find a new home . our daughter had a problem like this and after much expense was told to unhook every thing electrical she could . ended up being the radio/stereo in the trunk.
Mar 01, 2017 | 1999 Pontiac Bonneville
I have a set of subwoofers in my car powered by an amp with capacitor all 3 years old. A couple weeks ago I encountered a problem where my system will suddenly emit a weird loud humming noise (similar to...
try taking out the capacitor and wire the amp up with out it. it sounds like the cap is back feeding or discharging voltage when it should not be . if you reinstall the amp with out the cap and noise goes away buy a new cap or do away with it .
Oct 29, 2010 | Rockford Fosgate T600-2 Car Audio...
My yamaha YSP 1000 all of a sudden is not turning on. I have tried a different lead, but it still does not come on. Can you please suggest what the problem might me and the solution. I would also like to...
C515 ON THE MAIN POWER PCB (HAS 223 K 630HI PRINTED ON IT) HAS FAILED
Replace with a 22nf capacitor - Maplin part number N38CN
the new maplin part has a higher voltage rating and is bigger. it will need to be fitted with the leads extended with wire to get it to fit.
Sep 27, 2010 | Yamaha YSP1000 Main / Stereo Speaker
JL audio w7 is not working but not blown
Possibly the voltage spike/surge destroyed your subs. I am surprised you didn't lose your amp as well.
Apr 18, 2010 | Jl Audio 12W7 Car Subwoofer
Subwoofer pushing out problem
it sounds like one channel in your amp had shorted and letting dc go to the speaker...a speaker is an electromagnet and requires ac to make it pulse..the amp has a blown channel and would have to be repaired and a factory service center...there is no quick fix..
May 27, 2009 | Lightning Audio B1.10.4 Car Subwoofer
My amplifier stopped working? Why?
either smell your amp and see if it could have blown or the place that installed your deck didnt hook up your rca jacks
Mar 29, 2009 | DB Drive Speed A600 Car Audio Amplifier
Subwoofer problem
take a look at the amp is there a light on with the car running and stereo on? if no check the big black ground wire that connects to bare metal somewhere near the amp , also check the big red wire for 12 volts and the small wire for 12 volts let me know -jeff
Sep 12, 2008 | Lightning Audio B1.10.4 Car Subwoofer
Subwoofers help
Wire them up this way and see what happens. Bridge your amps output.
Amp+ to Sub1+
Sub1- to sub2+
Sub2- to Amp -
Nov 22, 2007 | Car Audio & Video
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
Car Audio & Video Logo
162 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
