Question about Zenith P42W46X 42 in. Plasma EDTV
Multiple vertical lines on screen.
Ive noticed alot of problems about lines, but none seem to be as bad as mine.
I got a Zenith p42w46x given to me by a friend. There is a thick vertical white line on the left side, a red and green line on the right side, and a few faint green and blue lines between. I dont mind the faint ones, but the big thick ones really bug me. Im not sure how old the tv is. Would someone please help?
  • 431 Answers
Hi I am Vortash Although this is trademarked as a Zenith the manufacturer of this set is LG and the prefix P42W46X is one of their set product numbers and is actually one of their RU-42W46X 10/11/12 -series televisions . The problem you are describing may be either incorrect display setting or incorrect picture fomat letterbox .. 4.3 pan or 16.9 widescreen I am guessing you do not have the manual for this set and I have found one on this site http://www.safemanuals.com under the LG P46W46X prefix FREE it may help you to solve this.
Another problem it may be is a power supply fault , components under heat conditions cann change value and restrict power flow causing many different faults this is particuarly true of semiconductors prior to failiure ..Try adjusting the set according to the manual and if this does not cure the problem I am afraid you are going to have to get the set looked at by an engineer . Regards Vortash
Posted on May 27, 2009
Lot of color line vertical on screen
most comun problem is the TCON-BOARD this card fix colors and sharpness on tv
Mar 04, 2014 | Zenith P42W46X 42 in. Plasma EDTV
My Zenith P42W46X 42 inch tv got two black lines vertical lines on the screen the were coming and going away before but they are more stable now.i opened it up and wiggled all the connections arround the...
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable near the black lines. Unplug the ribbon cable and look for black chips on the underside of it, I think they say 100 on them, you need to resolder both ends on each chip. Should fix the black line issue.
Oct 08, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Zenith 42" plasma p42w46x
I have just had the same problem. It affects both the component inputs but the A/V inputs are OK. If I disconnect the green input, the screen goes black and displays "No signal." Service guy came out and said the Y-board needed replacing. Haven't done this yet
Sep 01, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Vertical Color Lines with Sound
well I recently took my tv to a tv repair shop and they told me i had to replace the Y board and a Driver board. All in all it set me back $550.00
Aug 12, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Screen full of moving colored lines
I would suspect bad solder connections allowing a ground to "float" It is a common problem with the model P42W24BX which I believe uses similar circuitry as your model. An experienced repair shop should be able to get you fixed up.
Dec 18, 2006 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X 42 in. Plasma EDTV Logo
1,009 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
