Question about HP Pavilion dv7-1020us Notebook
Hp dv7 keyboard issue
HP DV7..some keys don't register [g, h, ', backspace]. i'm using onscreen keyboard to type. brand new computer. this problem occurred several months ago, but it seemed to resolve itself after waiting and rebooting. there's no dust underneath. what's wrong? is there a reset function. the laptop keyboard setting is the same as when i bought it.
Hey guys, I just had this problem, I have alot of problems with my DV7 laptop, top panel started malfunctioning, then it thought i was turning the volume up and down by myself, also my g h ' and backspace stopped working along with other problems that I don't want to bore you guys with, whats the answer? Remove the battery for 10-15 seconds and clean the connectors and this has ALWAYS fixed all my problems. Hope this helps.
Posted on Jan 26, 2010
I had the same problem and looked everywhere for a solution. Eventually I did was was suggested above, took off my keyboard and re-affixed the connector cable ribbon to its connector. It solved my problem perfectly and it wasn't hard at all.
This link does a good job of showing you which screws you need to remove to access your keyboard:
http://kcoppock.wordpress.com/2007/10/19/howto-replace-keyboard-on-laptop-computer-hp-dv6105/
but I found the following walk-through much more helpful - start with step 5
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
good luck
Posted on Jun 03, 2009
    Scholar:
  • 89 Answers
It sounds like the keyboad is faulty or not plugged into the system board correctly. If you know how to remove the key board, try to re-seat the laptop. If not your laptop will be under warranty and I suggest that you take it to a repair shop for repair.
Where do you live, if in Canada I can direct you to an HP repair shop in your area.
Posted on May 27, 2009
How do i re-attach the up arrow key on my hp pavilion dv7-6143cl? It has come loose but all of the parts are still intact.
Hello thf you look closely at the place where the key fits examine it and look to see if there are any broken tabs if not the key should simply press back in it does take some pressure and you should feel a snap when it is locked in place
Now if it does not then the key itself may be faulty which means you can get a another key from a old key board or just replace the keyboard itself they really are not too expensive ok
Hop this helps
Best regards Michael
May 18, 2014 | LotFancy Black keyboard for HP Pavilion...
My HP Pavilion dv7-3080us is having a keyboard problem. Pressing F8, or Backspace does nothing. The problem occured soon after purchasing the computer and simultaneously for both keys. The keys doesn't...
The keyboard got busted. If it has warranty send it back else you can shop for a replacement keyboard online. They are easy to install and doesn't require much work.
Jan 17, 2011 | HP Pavilion dv7-1130us laptop
''HP Pavilion dv7-1183CL Laptop Keypad Issue'' Keypad/NumberPad/NumPad is randomly slow, stuck, or disabled. The Keypad will not stay enabled. Holding down a number on the Keypad and pressing the Fn Key...
a new keyboard? or maybe the cable end inside is loose?
in ebay type, dv7-1183cl keyboard, see em,?
or read the manual called service, on that pc, at HP.com
see the 100 keyboards for 100 languages? yah.
one is yours, find it write down the P/n for yours
back to ebay and find it.
or ask at HP.com not here, we are not hp.
its that or virus infected.
we boot to a linux or windows PE live disk or stick
if the key works now, then you learned in 5min work
the problem is our unstated OS. is corrupted.
why not have tech, just fix it.?
May 30, 2017 | HP Computers & Internet
My HP Pavillion keyboard is keying properly
az i think your keyboard language has changed. from language bar you should change the language of keyboard. control panel-region and language- keyboard and language- change keyboard.
Apr 06, 2010 | HP Pavilion dv7-1020us Notebook
My esc key popped off of my pavilion dv7. do you
you can search ebay
or
http://www.individualkeys.com/servlet/the-14355/HP-DV7-Laptop-Keys/Detail
Jan 14, 2010 | HP Pavilion Laptop dv7-1025nr
The g and h keys don't function
Hello
Still? Was this the problem before? I have seen viruses that effect the keys. Download and run AVGFREE, MALWARE BYTES, and SUPERANTISPYWARE. Once these ae run, now how is the keyboard? If still a problem goto START, Run and type MSCONFIG. Once this is on the screen then select Disgnostic Startup. Save and Reboot. Only the basic OS will load. If the keys still don't work then it can only be the KB, KB connector, or mother board.
Sep 24, 2009 | HP Pavilion dv7-1130us laptop
Backspace key popped off
Replace the keyboard, the little frame underneath the key is bent or broken very easily. Replace the keyboard for $50 and move on...
Aug 22, 2009 | HP FS151UA Pavilion dv7-1170us 17"...
How to put hp pavilion dv7-1245dx key back on the
They just snap back on but notice if the key is broken then what you need to do at this point is by a replacment key or buy a replcement keyboard.
Jul 31, 2009 | HP Pavilion dv7-1240us Notebook
Keyboard on hp dv7-1130us stopped working
This sounds alot like a virus i once had!
try a system restore to the point before these problems occured. if that doesnt work run a full virus scan. If that doesnt fix the problem you may have to wipe the hard drive completly.
Apr 26, 2009 | HP Pavilion dv7-1130us laptop
HP Pavilion dv7-1020us Notebook Logo
6,156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
