Question about Sony PlayStation 2 (PS2) Console
Using my PlayStation 2 as a DVD player
When using my PlayStation 2 as a simple DVD player the picture is predominantly GREEN.I have fidled with various "tunings", etc on the tv set but I can't get any blue or red... Do I need a special lead or adaptor to increase the picture quality?
I realise you posted this ages ago and have problem got ris of your PS2, but i recently had the same problem and just got a new PS2 Scart with Gold contacts and it resolved it.
Posted on Mar 27, 2008
 just get another one
Posted on Oct 21, 2007
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    The color turns predominately green intermittently
    Please try to play any DVD movies to determine if the problem is on the TV or on the cable/aerial connection and reception..
    If you play DVD and works fine?
    The TV is good but the problem is on the aerial antenna if you are using analog..and if you are using digital cable please double check the connection and cable box..or try to contact your cable provider..
    Dec 19, 2011 | Olevia LT32HVE 32 in. LCD Television
    Vcr tape doesn't show on screen when playing
    If the picture from the DVD shows on the screen, but the pictire from the VCR does not, it is most likely because you are using sockets on the back of the player that are exclusively for the output from the DVD.
    Please review your connections in relation to the diagram below. If the cables from the player to the TV are only in the red box, you will not get any picture from the VCR. You will need to move the connections to the sockets in the green box or add a separate connection for the VCR using the sockets in the green box. Whether or not this is possible depends on what input sockets are available on your TV.
    You will notice the heading above the red box says "DVD". This means the connections in this section can only be used for DVD. The heading above the green box says "DVD/VCR" meaning the connections here can be used for both.
    There are a fews ways to set this up. To get the best picture quality from DVD, you should continue using any connections you may have in the red box and add another cable from the green box to the TV for the VCR. You will also need to select different INPUTS on the TV depending on whether you want to watch DVD or VCR if you are using 2 cables.
    I suspect this will be the cause of your problem. If you need any further explanation or assistance, please reply to me by clicking on "Add a Comment" below your question. If you would like me to draw a connection diagram between the DVD/VCR and your TV, please let me know the brand and model number of your TV.
    Hope this helps.
    Regards,
    BElectric
    Feb 26, 2011 | Emerson EWR20V4 DVD Recorder/VCR
    I am trying to connect a play station 2 to our Akira TV. I plug in the yellow Playstation plug to the green socker and then connect the sound. I don't get any colour in the picture. What could be the...
    You shouldn't connect the yellow into the green socket. The Red/Green/White sockets are for HD and therefore won't work correctly with your usually RCA cables. Your TV should have Red/Yellow/White RCA input somewhere. If not you may have to use a VCR or DVD player to connect your system to your TV.
    Dec 18, 2009 | Sony PlayStation 2 (PS2) Console
    Dvd player is on, but no picture is showing, just a green picture. tried different dvd discs, but still green
    What lead are you using? have you tried changing the lead, usually on scart leads they can go faulty , try changing the lead.
    jon
    Aug 10, 2009 | Sony DVP-CX985V Multi-disc DVD Player
    I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
    OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
    Jul 04, 2009 | Samsung Televison & Video
    How can I get my picture and sound back on PS2?
    According to the symptom the lens need replacement with new one, Change the lens and it will work fine again.
    Thanks for using fixya.
    Jul 01, 2009 | Sony PlayStation 2 (PS2) Console
    Color of pictures
    image quality occuring after long period of inactivity of the printer oftenis caused by inks drying up or clogging either the nozzle or the channels of your printhead. to prevent this from happeniong, i suggest you do the maintenance first: deep clean and calibrate the printhead before you start using it if you havent used it for quite a while. you might be experiencing a printhead problem if the printer is printing predominantly in one color. you should try to visit thsi helpful website. the link ive provided below:
    http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
    it should direct you to the right recourse regarding your issue...hope this helps..ciao!!
    Oct 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Color problem
    CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
    THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
    THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
    Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
    Color
    USING A CABLE OR SAT. BOX ?? IF SO CHECK W DVD
    Sep 03, 2007 | iLO 2600 Television
    Sony PlayStation 2 (PS2) Console Logo
    67 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
