Question about HP Officejet 5610 All-In-One InkJet Printer
When i try to scan any document im gitting the application is currently in use or unavailable , close any open programs and try again later . so please help me out to solve this pro.
  • kobitar May 11, 2010
    Here is your Solutions
    Canon PIXMA MP160 All-In-One InkJet Printer
    Epson Stylus Photo R300 InkJet Printer
    HP OfficeJet 6110 All-In-One InkJet Printer
    Lexmark X5470 All-In-One InkJet Printer
    Samsung printer
    Kodak printer
    & all printer's
    aaaaaa10
  • ultimitloozr May 11, 2010
    There are multiple methods for scanning documents with this device. Which one are you using? Are you using the HP Director or HP Solution Center? Are you trying to scan driectly into one of the MS Office applications? Are you using the Microsoft Document Imager? Are you just hitting the Scan button on the device?
Buy a new printer but make sure it is not a HP. certain to resolve your problem.
Posted on Jun 10, 2012
  • goran vukovic Jun 10, 2012
    buy a new printer but make sure it is not a HP. certain to resolve your problem.
MUKHTAR
  • 2022 Answers
SOURCE: My Officejet Pro 8500 won't scan, says "no scan options"
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 23, 2010
SOURCE: unable to print from laptop to HP Photosmart C3188
Did you try adding the printer using Administrator privs? Just go to the Control Panel > Printers > Run As Administrator > Add Printer. This process gave me access to the network printer. Unfortunately, MS Word will not work at all if the network printer is setup as the default and not added by the administrator.
Posted on May 01, 2009
mattballew
  • 89 Answers
SOURCE: hp photosmart c8180 scans a
is this a reoccurring problem? If not then restart your computer and it should be fine.
Posted on Nov 25, 2008
komguy
  • 2306 Answers
SOURCE: My Officejet Pro 8500 won't scan, although it did fine originally
It won't scan unless the HP scanning software is loaded and running on your PC, it needs to know where and how to scan, which is the scan options. It will scan and make a copy if you press copy, but it won't scan when you press scan unless that software is running.
Posted on Sep 10, 2009
  • 39 Answers
SOURCE: Scanner says in use when nothing is printing
These instructions will fix the majority of scanner2_bing.gif problems and networking problems using ethernet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
file. After selecting that file...you can then see your drivers
Posted on May 21, 2010
Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
Tip
Keyboard Shortcuts
[Alt] and [Esc] Switch between running applications
[Alt] and letter Select menu item by underlined letter
[Ctrl] and [Esc] Open Program Menu
[Ctrl] and [F4] Close active document or group windows (does not work with some applications)
[Alt] and [F4] Quit active application or close current window
[Alt] and [-] Open Control menu for active document
Ctrl] Lft., Rt. arrow Move cursor forward or back one word
Ctrl] Up, Down arrow Move cursor forward or back one paragraph
[F1] Open Help for active application
Windows+M Minimize all open windows
Shift+Windows+M Undo minimize all open windows
Windows+F1 Open Windows Help
Windows+Tab Cycle through the Taskbar buttons
Windows+Break Open the System Properties dialog box
on Apr 04, 2011 | Computers & Internet
How do set up my lexmark pro901 to scan to my pc so that I can email the scans
Make sure the Lexmark Pinnacle Pro901 printer driver is installed on your computer. If you have the install disc that came with your printer, just insert it to your computer hard driver and follow the instructions on your computer screen. You can also the download the printer driver from the Lexmark website at http://bit.ly/d3ftso. Select your operating system > download > execute the file. Again, just follow the instructions on your computer screen.
Note: The install disc contains the Lexmark OCR scan software necessary for scanning documents for editing and saving them as PDF files. The downloaded driver does not contain the OCR software.
To scan to your computer using the printer operator panel:
1. From the home screen, navigate to Scan to Computer: Scan > Scan to Computer
2. Touch USB-Connected Computer or the name of a network computer. The local or network computer is the destination that will receive the scan. Wait until the printer has finished downloading a list of the scan applications available on the selected computer.
3. Select an application (in your case your email), and then touch Accept.
4. Select the color, resolution quality and the original image size. If necessary, touch Accept each time you make a selection.
5. Press the start button to start scanning. The scan is complete when the application you selected in step 4 opens on the destination computer, and the scan appears within the application as a new file.
To scan to your computer using the printer software (Lexmark Printer Home):
For Windows:
1. Click Start.
2. Click All Programs or Programs, and then select the printer program folder from the list.
3. Select Printer Home.
4. Choose your printer from the printer drop-down list.
5. Click Email, and then select Photo, Document or PDF.
Note: You can select Document only if an OCR application is stored on your computer. Scanning starts and the scan progress dialog appears.
6. When the scan is finished, a new e-mail message is created with the scanned document automatically attached.
7. Compose your e-mail message. Note: If your e-mail program does not open automatically, then you can scan the document to the computer and then send it through e-mail as an attachment.
For Mac:
1. From the Finder desktop, double-click the printer program folder.
2. Double-click the printer Center to open the All-In-One Center.
3. From the "What is being scanned?" menu on the main screen, select a document type.
4. From the "How will the scanned image be used?" menu, choose To be viewed on monitor/web page.
5. From the "Send scanned image to" menu, choose an application.
6. Click Scan.
7. Retrieve the scanned image from the application, and then send it through e-mail as an attachment.
I hope this information has been helpful.
Sep 19, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
May 20, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Regards
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
After scanning the first document and saving the file the scanner will not scan another document. I have to close it and open it back up to scan another document.
your memeory does not allow to scan more than one documents and when you close and reopen it refresh the temp. memory in your system...try to clean all cach and and clean the system or close some of the background applications that is running.
Nov 07, 2009 | Fujitsu ScanSnap S510
"Media not recognised" Documents to Go error
- Eject the card - Open Document to Go - While still opening the application (in the browser screen), insert the card back to device. The browser will show the card on the top right. - Just close the application as usual. Reopen again, and it should be back to normal.
Sep 23, 2009 | Palm Tungsten E2 Handheld
Evrytime i open my documents have a dsplay File Corrupted! Please run the virus-check , then reinstall the application. ok then hve another dsplay explore.exe/ application error. so what im going to do?
your file could be corrupted in any case you can right click that certain file and run a virus check process, i assume you have anti virus software, once the process is finished you can try to open up again, if this is a word document (microsoft) sometime you can recover the file again.
hope this helps
Jul 10, 2009 | Computers & Internet
Hp psc 1513 all in one series scan problem
reformat your system so that you can install properly your HP printer, this time the system are being invaded with spywares & viruses...
Jun 18, 2009 | LaserJet 3052 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
2,540 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
