Question about Dell Dimension 3100 PC Desktop
Laptop Is it advisable to keep the laptop charged while working.
    President:
  • 2,004 Answers
Yes keep the laptop charged while in use. But once in a while use unplugged to discharge the battery
Cheers.
Rate fixya.
Posted on May 27, 2009
  • Onifade Adewunmi
    Onifade Adewunmi May 27, 2009
    Rate my solution please.
    Brigadier General:
  • 3,917 Answers
No. Please charge only when the battery is dying. This would help improve the battery life as well.
    Scholar:
  • 34 Answers
It depends on the type of battery. NiMH and NiCAD batteries are much more susceptible to "memory" in which case a film builds up on the boundary of normal use making it so that the battery will only function in the range that it is usually asked to. In other words, if you only ever use it for short periods of time, eventually it will appear to only hold a charge for a very short period of time, this would include if you always operated the laptop plugged in. You can fix this somewhat by trying to take it through full charge and discharge cycles to try to reclaim some of the lost space. NiCad and NiMH batteries are not used in many laptops these days but are still used in many other consumer devices such as cordless phones and cordless power tools.
Lithium Ion batteries used in most laptops these days. They tend to be lighter weight and less prone to "memory" issues. It is still not a bad idea to, from time to time, completely discharge the battery and charge it, but it is not as critical as with the other types of rechargeable batteries.
Finally, be very careful of temperature extremes with a Lithium Ion battery. Heat and cold can kill "cells" within the battery greately affecting their capacity. Try not to leave your laptop in the car on a hot day or overnight when temperatures get very cold or else you may find that your battery capacity is greatly reduced.
  • 489 Answers
Actually its good working without battery. but also has some problem if electricity doesnt clear (i mean frecancy) you will hurt to Mainboard.  the battery makes correct bad signal. i think  laptop must use with battery.
LAPTOP NOT CHARGING
With Dell you have to use Dell OEM chargers to keep all the functions. Like charging and use at the same time. Otherwise it wont do both. Look on Ebay for a genuine Dell charger or go to Dells website. Be advised that it might be the jack on the computer though.
Apr 28, 2014 | Dell Inspiron Computers & Internet
No Battery Warning - Turning off at 20%
May be time to replace the battery.. or charging problem i advise you to take it to the service center.
Aug 13, 2013 | Fujitsu LifeBook Computers & Internet
IS IT SAFE TO KEEP THE LAPTOP BATTERY OUT FOR LONG PERIODS
Yes, it should be fine to remove the battery from the laptop if it is not being used, as there would be a minimal drain on the battery if left installed for an extended period.
Keeping the battery at approximately 75% charged should also be fine and would be recommended as part of a practice to extend the battery life that is advised with common battery maintenance instructions.
Jan 05, 2012 | Dell Computers & Internet
Aspire 4736z not charging. charger is good and baterry is new. please advise if software or hardware problem
I would say it was a hardware error. If the laptop works on a battery that has charge in it then the motherboard charging system may be faulty. I would leave the battery on charge for a good few hours as if it is new it will take some time to be recognised, or is a faulty one. Have you a coleage with a similar laptop that could test your battery/charging system?
Mar 28, 2011 | Computers & Internet
What does it mean when the battery icon light it flashing yellow?
If the battery indicator is flashing despite it is being charged, then the battery has internal problem which means, it's need replacement. Please check that the battery is not physically damaged and check the voltage. Keep it outside without charging or installing on the system for few hours and try again. If this doesn't help, you'll need to replace it. Good luck. Thanks for using FixYa.
Jun 09, 2010 | IBM ThinkPad T60 Notebook
I have a Dell Studio laptop. Will power on with
This should have a "battery check" button on the battery itself. Remove the battery and press the button. If it reveals that the battery is not fully charged, or you cannot get it to take full charge, perhaps all that you need is a new battery. If the battery is failing the check the system makes on it at boot, it won't.
Jun 14, 2009 | Dell Inspiron 1501 PC Notebook
My hp compaq laptop nx6325 refused to charge its battery. It works normally with the ac adapter but goes off whenever I remove it from the ac circuit. The same battery was taken to similar laptop for...
If the battery charged in another system, but not in yours, then most likely you are looking at a motherboard replacement.
Average cost for motherboard is around $200, if you have it installed by a technician, another $100 or so.
Feb 28, 2009 | HP Compaq nx6325 Notebook
Laptop power connection faulty
Hallow Dear,
As your explanation about Battery issue simply I’m advising you to replace your battery with original one.
But before that there is one thing that you can try it out.
---Use your laptop until battery goes down & shutdown automatically then remove the battery and try to discharge it completely with small bulb manually
When it’s on completely discharge (0 Volt) keep it on Outdoor Sunlight about 12 hours.
After that connect it to your laptop & recharge it completely (until Computer LEDs showing you as Fully Charged)
****** REMEMBER DO NOT TURN ON YOUR LAPTOP******
Until its Showing you as fully charged
That will be nice if you can check Battery Voltage & Amperage manually as it is charged fully before turn on your laptop. (if not you can give more charging time accordingly)
This will not solve your any component (thermal fuse, vRegulate) problems inside your battery but will increase your battery Cells Life and most vStoraging problems on Cells inside your battery
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv6000z Notebook
I have dell Inspiron 6000 laptop computer which has a charging probelm. I have to always keep ac adapter connected so it works. Please advise me. Thank you. Vinay Shah
The problem you are facing is battery drain out, the cells in the battery are not capable to get charged of to give charge and they have to be replaced - So my advise is to replace the battery and get a new one. Contact dell or local sales office in your nearest area. Also compatible model batteries are also available.
Jul 05, 2008 | Computers & Internet
Pin stuck in charging jack!
It is broken, you are going to have the DC jack replaced.
Dec 27, 2007 | Acer Aspire 3680 Laptop
Dell Dimension 3100 PC Desktop Logo
87 people viewed this question
Alun Cox
