Question about Refrigerators
Green light on ice machine is on but starts to blink, I reset and same thing happens,there is ice in the freezer tray but it won't release.
    President:
  • 1,952 Answers
What is ur refrigrrater model and brand ..............then try adjust the cooler switch and off the main switch 10 minites after on the switch ...............
Posted on May 27, 2009
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi May 27, 2009
    door seal check try to another plug point then electrical loose connection try to change the bulb
    According to GE this uses a 40 Watt appliance bulb. You should be able to get one from any department or home improvement store.
    defrorst light is blinkig
    You can sometimes tell by the control system and display. LCD are the
    most recent, then green LED, older is Red LED, and older still is fewer
    and fewer lights, then mechanical thermostats.
    They used the electronics available at the time - so compare this to other household appliances like videos.
    Next is the brand. Good brands tend to outlast others 2x - 5x, and spares are easily available.
    If it is a large unit, it may be cost effective to have an engineer
    replace the compressor or service it rather than scrap it, and just
    judge the price of parts vs a new (cheaper quality) unit.
    Usually the older the unit is, the more reliable it is thesedays.
    Hope this helps with your decision.
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
My Daewoo side by side refrigerator ice tray is not spinning over to release the ice how can this be remided
First thing I would do is to try a reset. Here's a YouTube video showing how to do this: Daewoo How to Reset the Ice Maker American Style Fridge Freezer
and here's a generic "how to" guide on troubleshooting and repairing most types of refrigerator ice makers.
Ice Maker Troubleshooting Guide
Aug 12, 2016 | Daewoo Refrigerators
Start upnormally ..fter30 seconds water fill light starts blinking and will not make ice.
Ice is not made until freezer temps hit 10 degrees or less. And it takes a few hours till unit cools down. If freezer is cold enough and still no ice check to see if water has entered the ice tray. If not, check for solenoid operation, power to solenoid, water supply to solenoid.
Feb 23, 2016 | Refrigerators
Hoshizaki kml-250mah Ice Machine Problem. I had someone clean the ice machine and every time it leads to a service call I just can't afford. I get two a beep error. Now I replaced the filter, here's...
I see 2 issues for one ur water inlet valve may have gone bad the coils defective u can test it with a multi meter or any appliance parts store should be able to test it for you, also should do a live volt test on it as well. check for full 120, next thing that thing u said that measures temperature? Its called a thermistor and there should be atleast 1 or 2 in ur freezer and maybe 2 or 3 in ur fridge. and it should not be jumpered other words u will get variable termperatures. it should be tested with ameter and should show about In most models around 1300 ohms ( give or take 150 ohms)
Mar 29, 2015 | Hoshizaki Refrigerators
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Makes ice but will not dispence ice
Hello Kaboris3,
If your ice maker is making ice but fails to eject it, you may have a faulty mold release heater. If the ice tray is cycling in its loop... and is positioned to drop ice but the cubes are not being released, that will happen if the heater fails to turn on to relase them. Try power cycling the fridge to get things back in sync.. ( unplug the fridge for a few minutes then plug it back in ) sometimes that will get things started again. If that fails to work, you may have to defrost your freezer to meke sure the ice maker isn't stuck in one spot with ice... if you get too much water in the tray, it may spill over and freeze and restrict the ice tray conveyor from rotating. Depending on the model, you can remove the front access cover to the ice maker to see if the motor is running ( very slowly but should cycle if you watch it carefully).. Those are a few ideas that you may consider trying.. Hope that helps you fix your problem... worst case scenario is remove and replace the entire ice maker assembly.. most are plug n play assemblies and easily installed... Good Luck !
Nov 29, 2009 | Frigidaire Refrigerators
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
Jul 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore fridge optical icemaker hosed
ice maker module assembly is probably broken
Sep 27, 2007 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
