Question about Yamaha CDC-685 5-Disc CD Changer
Note: CDC-625 unit won't open, no discs inside
The Yamaha CDC-625 compact 5-disc player in my sound system has stopped opening. The power works, there's no disc in the machine, and I can hear a humming sound like a motor, but the unit doesn't open. It's an old machine (bought in 1992) but very lightly used. Is it worth trying to get it fixed?
  • eaf May 28, 2009
    Thanks for the recommendation. I'll add a new one to my Wish List.
Wait, wait!
I bought one of these units from a flea market for $5.00. It said the tray wouldn't open. I picked it up, and noticed the same thing you did. Humming motor, but the tray stayed put.
I opened it up to check things out, and all that was wrong was a (very) stretched out belt on the pulley that opened the tray. I replaced it with a rubber band and it has worked ever since. Once the rubber band wears out I'll replace it with a proper belt, but for now, it was a 2 minute fix that's lasted around 11 months so far. I really, really like this player, and plan to keep it working for a long time!
Posted on Jun 23, 2009
Yes, its the belt that is the issue. I found an o-ring the same size in the plumbing section and it works as good as new now
Posted on Nov 28, 2009
  • 6,784 Answers
Hi, this is a failed load motor. the windings are busted, in return, making it weaker than normal. it will not be able to move the gear assembly in this case.
The bad news is m the actual replacement parts for your unit has been discontinued. this will make it hard to repair.
I would cut the loss and just by a new unit. you wont be able to purchase any repair parts for this unit.
Posted on May 28, 2009
How to fix Magnavox compact disc carousel changer that has no sound?
Is there sound through the headphone jack? Have you tried other audio cables to connect it? Look for a reset button or with all discs removed and the unit powered on, hold the power button for 20 seconds and see if that resets it. This works for many electronic computer controlled devices.
Sep 12, 2014 | Magnavox Cdc 748 5 Disc Changer
Sherwood CDC-5506 5-Disc CD Player - does it need Amp ?
Yes you need and amp Look at the disc player there is no volume control or speaker outputs.
Nov 21, 2013 | Audio Players & Recorders
Yamaha CDC-645 not playing
The lazer is shot. Could cost $150 to $280, to have it (repaired)
Oct 22, 2012 | Yamaha CDC-685 5-Disc CD Changer
How do you replace the belt drive in the Yamaha CDC 615?
The drive belt on my CDC-615 stretched out this year too, and needs to be replaced. Unplug the CDC-615 from power. Remove two screws on the left side of the housing, two screws on the right side of the housing, and one screw from the middle top of the rear panel. This will allow the top panel to be removed.
Temporarily re-connect the CDC-615 to power and power it on. Press the "PlayXchange" or "Open/Close" button, which will drop the laser pickup/play head and spindle, and start the open/close motor. Power the CDC-615 down while the motor is running, to leave the laser pickup/play head and spindle in the "down" position. You should now disconnect the CDC-615 from power once again.
From here, you can simply push on the CD tray from behind, until it's in the fully open position. This will reveal the drive wheels (one large and one small pulley) just beneath the tray on the left side, with the tray facing you. This is where the replacement belt goes.
Reverse the steps to put it back together.
Oct 02, 2012 | Yamaha CDC-615 Natural Sound Compact Disc...
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
Yamaha 5 disc player
what brand and model bor....is it Yamaha CDC series?
Reden
Feb 09, 2008 | Yamaha CDC-765 5-Disc CD Changer
Yamaha cdc 555 5 disc cd player
If you trust yourself enough to open the case w/o breaking stuff, then open it up UNPLUGGED, locate the laser lens (small,clear,plastic) gently clean the lens with a swab of lens cleaner for glasses.
Also clean the chrome runners that the laser assembly tracks on.
Jan 16, 2008 | Yamaha CDC-565 5-Disc CD Changer
Yamaha CDC-685 5-Disc CD Changer Logo
2,015 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
