Question about Xerox Office Equipment & Supplies
Printer on startup does not work...system error 07,010.43:73884
The printer upon start up does not work and gives a system error 07,10.43 (maybe a blocked print head ???)
    President:
  • 2,072 Answers
That problem is related to the print head not moving properly.
What is the model number of the printer? If you want me to send you instructions E-mail me rak458@aol.com. I will be glad to work you through this.
Pretty common problem and rarely requires parts to repair.
Posted on May 28, 2009
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c-c 152
I think your problem comes from the scanner, try the operation if you have anotherPWB-C when you turn on the machine.
5/16/79 CC151: Error upon startup ROM contents (MSC)
5/16/80 CC152: Error upon startup ROM contents (Scanner)
5/16/81 CC153: Error upon startup ROM contents (PRT)
5/16/82 CC154: Error upon startup ROM contents (PH)
3 Replace the Appropriate board.
Apr 25, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
We have an Aficio 2238C that is giving an error message upon startup. It says functional problem, turn off unit and turn back on, etc.... error number SC471.\r\nI have tried the "yellow...
Probably this happened after a paper jam??? Yes???
This error is related to the Tranasfer Unit.
This SC 471 can be cleared by removing and re-installing teh Transfer Unit.
If this doent work you probably have to replace a mylar. For that i advise you to call a technician
Apr 07, 2011 | Ricoh Aficio 2228C Copier
I had to bring a computer home from our office where it was connected to a network. I am trying to install the printer CD for the HP LaserJet 3055 printer and at some point in the process, I get the...
Go to START >>> RUN then type msconfig..(click on OK). It should bring up System Configuration window. Go to STARTUP tab then un-tick the entry you think is the DOS Command String. This should disable it from running during startup. Restart the computer.
Nov 10, 2010 | Office Equipment & Supplies
Printer HP Photomaster C4680 caused error.
* Install the printer first and perform the following steps:
1. Click on Start >> Run (or in the 'Start Search' box).
2. Type MSCONFIG
3. Click on 'OK'. The Configuration Utility should open on the screen.
4. Click on the 'General tab'.
5. Choose 'Selective startup'
6. Check 'Selective startup'
7. Click on 'STARTUP' tab.
8. Uncheck all the programs which start with 'HP' or 'hp' except for 'hpqtra08'.
9. Click on 'OK'. Restart the system
If you are getting a message "System Configuration Utility, you are using the selective startup for troubleshooting your system", I suggest you check the check box in that window and click on 'OK'. This occurs if you are using the Selective startup option and not using the normal startup to reduce the number of startup programs.
Now verify the result
:) Dr Tony
Apr 20, 2010 | HP Office Equipment & Supplies
System error
System error upon print option may be caused due to:
  • Improper device driver (printer).
  • Any corrupt file.
  • Any hardware error
Check all these before you start printing, Try to check a test print also..
Jan 21, 2010 | Brother P-Touch PT-2600 Printer
Dell precision m4400 blue screening"system has recovered from a serious error"
"BSOD" also known as "Blue Screen of Death" occurs when system is not stable due to misconfiguration or driver incompatabilty or Virus or worm infection.
Method 1 :  Start your system by pressing F8 upon startup. Select "last know good configuration that works".check this one solve your  porblem.
Method  2 : Start your system by pressing F8 upon startup. Select "safe boot "and check if it work or able to log you into your Desktop.
Uninstalled any software or hardware you have recently added or installed.Click "Start", Select "Run", type "msconfig"
Again click "Startup" tab.Untick all the program thats loads during your system Boot up.
Method 3: Start your system by pressing F8 upon startup. Select "safe boot "and check if it works or able to log you into your Desktop.
Click "Start", and then select "All programs", then "Accessories".Select "system tools" and then "System Restore".Try to restore your PC to a point or date which you know it was working fine.
Method 4 : If none of the above workor you are able to boot it. Then download "Hiren's Boot CD"
Here is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Download the file and burn the ISO image in a CD.Boot your system using that CD. It has lots of tools for repairing Windows, system restore, Data recovery etc.Check if it can fix your problem.
If Hiren's Boot CD can't fix it then Backup all your important datas and go for a new install.
Don't forget to create system restore point whenever you are going to make changes to your system.It will help you in recovering during the time of failure.
HAPPY NEW YEAR.
Dec 31, 2009 | Dell Mobile Precision M4400 Notebook
Upon startup i get an error: configFree has stopped working. I run the virus program Norton 360 but it says no virus. before this i was installing an application and it gave me the "you need to be the...
I would reinstall your operating system fresh after doing a full format, remember to back up your hard drive. I have never had satisfactory results from any virus scanner or system restore.
Oct 26, 2009 | Toshiba Satellite M45-S265 Notebook
Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
32 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
