Question about SharpVision XV-S96U Multimedia Projector
Image not being displayed through projector
I have a Sharpvision XVS96U LCD Projector, that was working just fine with an older computer. I decvided to upgrade to a newer, faster computer with more memory, and had a Dual VGA video card installed so I could display the image on a screen for the public through the projector, and at the same time manage the images on the primary monitor. Problem is, I am getting nothing through the projector, I have run the Dual mode video wizard many times, and yet the problem persists. I have set up my primary and secondary monitors, and nothing seems to work.Do you have any ideas how to get the iomage to display through the projector?
  • meteshadow May 11, 2010
    did you go to grapic card website.? maybe there is a firmware ot something about this problem.
  • 2,237 Answers
Make sure the resolution matches. the projector uses 640x480.
Posted on Aug 04, 2009
My Canon LV-5210 displays no image for my computer. It has worked fine in the past. And it did not work a couple days ago and then it worked OK yesterday when we accidentently pushed the Input buttom. But...
If your projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F2 or F2 once: The laptop screen only
* Press Fn / F2 or F2 twice: The projector port only
* Press Fn / F7 or F2 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
this should help you :)
Aug 26, 2010 | Canon LV-5210 Multimedia Projector
Polarview 211e
Go to:
System Preferences (you can get there by clicking on the Apple Menu in the top left corner) -> Displays -> Detect displays
After you click "Detect Displays" your G3 should automatically send the display image to your projector.
Feb 27, 2008 | Polaroid Polaview 211E Multimedia...
HOW TO USE DAYLIGHT PROJECTOR IN STEP BY STEP
Hi LCD projectors have revolutionized the audiovisual industry. With a few clicks of the mouse and strokes of the keyboard, whatever you type on your computer appears instantly on a projection screen in real time. If you have never experimented with an LCD projector, however, do not worry. You can learn how to use an LCD projector.
  • Plug the LCD projector in to a power outlet. Completely plug the power cord in to the back of the LCD projector.
  • Step 2Use a VGA cable (usually a 15-pin male to male) to connect your computer to the LCD projector. Insert one end of the cable into the VGA connector (sometimes this connector is blue) in the back of your computer and do the same in the back of your LCD projector. If the LCD projector has more than one VGA connector, choose the one that says something like "line in" or "in from computer."
  • Step 3Power on your laptop. Turn on the LCD projector. It may take a couple of minutes to warm up. Open the computer file or document you wish to display. When you are ready to project your image, press "Function" (Fn) plus "F8." This combination of keys sends your computer's display to the LCD projector.
  • Aug 03, 2010 | BenQ (200NSH-LAMP) Projector Lamp for...
    LCD projector not displaying image of the laptop
    On that Dell, you have to tell the laptop to display the image on an external unit--look on either F4 or F8--you will find a small TV screen symbol. You have to press and hold "alt" and press the key. The options are, 1-show image on just the laptop, 2-show the image on the laptop *and* something else, (like a projector), or 3-show an image on JUST an external display. NOTE: Sometimes, you have to turn on the projector FIRST, then immediately turn on the laptop so they boot together--just one of those strange things...(remember, **for example** first press of "alt" F4 will get you laptop and projector, second press of "alt F4 will get you JUST the projector, third press of the keys will bring you back to just the laptop)---Rick
    Sep 07, 2009 | Panasonic PT LC75U Multimedia Projector
    Input Screen shows a permanent image
    resolution issue. reset the settings to factory default. if that doesn't solve it, make sure the resolution on the projector matches what is on the computer. and it should take mac ok. also check the cable.
    Aug 27, 2009 | SharpVision XV-Z9000 Multimedia Projector
    What is a blue lcd?
    Your LCD panel of the projector seems to be malfunctioning , provide the model details.
    Feb 01, 2009 | SharpVision XV-Z1U Multimedia Projector
    Left half image has greenish tint, other half fine XV Z9000U
    I am having the same issue, did you ever get yours fixed and if so how please?
    Shannon
    Nov 25, 2008 | SharpVision XV-Z9000U Multimedia Projector
    Image has big yellow
    Hi Zenmast
    This is a burnt LCD that will need replacement. If the circle is yellow on a white screen , then it is your blue LCD that will need replacement.
    Apr 22, 2008 | SharpVision XV-Z1U Multimedia Projector
    LCD projector does not display video
    YOu have to swith to LCD on your laptop, or Video Card, setup, this is in control panel, video , and advance settings, usally, you have to see 2 panels, select according and see what happen on the LCD. if any image came .
    good luck
    Nov 14, 2007 | Dell OptiPlex GX620 PC Desktop
    Blue dot in upper center of sceen
    there is a burn spot on the light filter on the blue lcd. you can call a sharp service center to purchase the part, but it's extremely involved to replace.
    Oct 08, 2007 | SharpVision XV-Z1U Multimedia Projector
    SharpVision XV-S96U Multimedia Projector Logo
    186 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
