Question about Palm Tungsten E2 Handheld
Alm one The screen won't work with the stylet cannot use the palm one anymore, ful ly charged, tried to adjust screen with the target and stylet tried to reset at the back What else can I try
    Scholar:
  • 46 Answers
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Tungsten E2.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Posted on Nov 09, 2007
My ipod won t charge
It could be 1 of 2 things. The first 1 I have had the experience of accidentally leavng my iPod plugged in charging for over a day. What happened...it killed the ability of the iPod to hold a charge & yes I tried with another battery & it was a no go. The second issue could be that your actual power supply cable has gone bad and won't work anymore. Now you didn't specify on which manner you're trying to charge it so if I didn't address your issue my apologies. There is a 3rd thing and no its not a combination of the 1st 2 I mentioned happening in conjuction...The 3rd thing could be that the power outlet you're trying to use doesn't work anymore so try another outlet plug.
Oct 23, 2013 | Audio Players & Recorders
The screen won't turn on anymore after I took it apart to switch out the charging port.
I see a crack in screen on top right but it should still display (however touch won't work). Look at the ribbon connector which connects display to the phone PCB, it should be firmly secure in its connector.
Also try cleaning the PCB with alcohol, if still doesn't work then either you need a new LCD or some chip is blown.
Nov 10, 2012 | Lands Phones
Computer cannot communicate with printer
Check if your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
Also, make sure that you're using genuine Lexmark cartridges. If there's an error message on your screen that your black ink is low even if you replaced it, you won't be able to print or scan. It will send a busy signal or communication not available to your computer. If this is the case, replace the cartridge.
If it still doesn't work work, try to reinstall the software: http://bit.ly/d3ftso
May 11, 2012 | Lexmark 90T9105 - Pro 901 All-in-1
My asus p552w has align screen problem... when i enter this option it doesnt come out of it... just that target moves when i click/tap on it... it was getting clicked on right portion of the screen only so...
Hi Prash,
The solution is simple. Please tap the screen exactly in the center of the '+' sign that appears on the screen. The + sign or the target keeps moving till the screen is not alligned. I faced the same problem and searched and found your query on many forums but no luck. So I actually resorted to aiming the target with one eye closed...and the damn thing worked in one shot.....Now my default settings have been installed. Lets see what is in store on the other side of the default installation.
New Asus P552W user!
Nov 17, 2009 | ASUS Computers & Internet
I need the instructions for alarm clock model number cc208s
Please try this....
Setting the Clock
1. Press and hold the Clk Set Button.
2. While holding the Clk Set Button, press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute.
3. Release the Clk Set Button to set the time.
Setting the Alarm
1. Press and hold the Alm Set Button.
2. While holding the Alm Set Button , press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute for the alarm time.
3. Release the Alm Set Button to set the time.
4. Adjust the Auto/Off/On Button to Auto.
5. Adjust the AM/FM/CD Switch to the desired function for the alarm, or reduce the Volume Dial to "Buzz" to wake to the unit’s buzzer.
Cheers!
Jul 13, 2009 | Audio Players & Recorders
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Mar 25, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence Problem and Contrast Adjustment
Have you checked all of the resistors inthe convergence circuit as well? If not, check them for the correct impedance.. Remember, you have to pull one side of the resistor out of circuit to measure it correctly.
If all of the resistors are good, then you have to do a coarse convergence adjustment on the set through the service menu.. if you need the service manual for the convergence directions, I have one uploaded in the technicians corner of techlore.com
Dec 25, 2008 | Televison & Video
Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Dec 09, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
Palm Tungsten E2 Handheld Logo
79 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
