Question about Hayward H Series Pool & Spa Heater 150k Btu Propane Gas Milivolt Ignition H150p1
Hayward h150 gas will not fire up.
I can here the electronic ignition and smell the gas. but no fire. the model#h150edi its about 9 years old.
SOURCE: Hayward Heatmaster will not light
Also if the filter is heavy with dirt, try recycling the filtering element, (sand od Diatomea sand) add new for a fresh start, this use to solve my problem.
Posted on Apr 25, 2009
craigjamesbt
  • 65 Answers
SOURCE: stove burners won't ignoite
just to be clear I am assuming that you can in fact see a spark traveling from the ignitor to the metal surface over where the gas should be expelled... that being the case you must remove the the gas burner from the stove and check for damage or sign of deterioration ie: cracks, rust holes, missing sections etc. more than likely if there is no damage after 7 years of use the problem will be in the form of carbon and rust deposits inside the burner pieces or associated piping (pipe that are in the burning side of the system don't tear into the gas side) *NOTE THIS WILL NOT KEEP GAS FROM COMING OUT BUT MAY PREVENT IT FROM EXITING IN THE PROPER PLACES DESIGNED FOR LIGHTING* you can clean these carbon deposits by tipping the open end face down and tapping the burner pieces with a block of wood or similar device. These deposits should fall out as a heavy black or reddish brown dust you can also try vacuuming it and running an appropriately size drill bit through each of the burner holes to clean them as well or you can probably just purchase a new one by ordering it from the place you bought the stove
Posted on Apr 26, 2009
protek480
  • 1714 Answers
SOURCE: WONT FIRE UP Hayward h150 Pool heater
Is the thermocouple in the pilot flame? It has to sense the flame and provide a signal to light. or, is it a flame sensor? Same thing, must be sensing the pilot flame. This is the first step for it to light...
Posted on Jul 23, 2009
  • 10865 Answers
SOURCE: Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Posted on Oct 02, 2009
thepool
  • 78 Answers
SOURCE: Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Posted on Apr 23, 2010
Hayward heater h150 ignites and shuts off
check pilot generator if 500 millivolts to gas valve turn on switch if lowers should light if not check wires could be loose make sure flame sensor is above burner if not it wont sense flame
Jul 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
Why is my Hayward heater h150 igniting and shutting off?
I have seen this happen when there is a flow problem with the propane. Dont rely on the tank gauge.
H150 heater shows 1f
IF is ignition failure. Verify that you have a good Ignitor and that your gas supply is adequate to fire the unit. I rarely see the internal gas valve fail on any Hayward unit. Be careful if you have to put your hand in there. The electric circuit on the smaller heaters is not typically 24VAC, it is usually 120VAC in the U.S.
May 24, 2014 | Hayward H-series Electronic Gas Pool...
I can't light our pilot light - Hayward H150
I dont thnk you have a pilot light on this model ... I think it is lit by a electronic device that glows.
Remove the front cover and look up into the burner area. Turn the heater on. Can you see a red glow?
Aug 05, 2011 | Hayward H-series Electronic Gas Pool...
Can an H150PI pool heater be converted from propane to natural gas
On this heater, the conversion may be a kit that replaces all the orifices. In any case if you call Hayward technical support they should be able to provide the correct solution. I hope this helps.
Jul 27, 2011 | Hayward H-series Electronic Gas Pool...
Pilot lights but won't stay light on release of Pilot button
Replace the thermocouple that the pilot light heats up to keep the gas on.
Jul 07, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series Pool & Spa Heater 150k Btu Propane Gas Milivolt Ignition H150p1 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
