Smps fan is not rotating - Computers & Internet
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Please remove the fan ... clean it.... re fix it ...if it is still not working, change the power source of the fan on the board ....... if it doesn't work, please replace the fan.
Posted on May 27, 2009
    Teacher:
  • 27 Answers
Might be because youre computer dont have a low power supplier.
Id recommend download.com to find a new one
Computer does not turn on
1. Does the monitor power on ?
2. See the signs of live on the power supply ?
3. Does the fan on the power supply in the rear rotate ?
4. Do you see any led glowing in the power supply box through the fan grill ?
5. Try to replace power supply unit also called SMPS.
6. Make sure you buy the right SMPS capacity, physical size, output pins configuration.
Apr 22, 2016 | Computers & Internet
My computer will not power up?
Check the SMPS fan working. Check the mains cord. Then open the PC. Short green wire with black wire by using paper clip while keeping the mains ON. The SMPS fan should rotate. If not, replace the SMPS. Also check the CPU fan.
sonsunny
Jun 15, 2011 | Dell Dimension 2400 PC Desktop
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
No power coming on intel desktop motherboard d845
Check the power supply to the motherboard i.e the SMPS, if it is working the fan of the SMPS will rotate. If the SMPS is ATX you can check it without connecting it to the motherboard. Unplug all the SMPS power connectors from the motherboard and then short circuit the green and the black wire of the 20pin connector of the smps, if the SMPS is working the fan of the SMPS will rotate. If the SMPS is in good condition and working, than it might be a problem in the internal circuit of the motherboard.
Check the process here:-
http://www.jestineyong.com/?p=267
Jul 19, 2010 | Intel D845GVSR Motherboard
What is the value of rectifier used for cooling fan in smps
its cheaper to buy a replacement fan because if you make a mistake during manufactuer then it may cause other problems,replacement fan in NZ about $30 and comes with warantee
Apr 27, 2010 | Dell (6F858) Cooling Fan
Pc not switching on even after changing smps. even fan not switching on in smps
Dear,
You can test you smps simply by shorting any of the back wire and green wire. this will switch on your smps withour connecting with mother board. IF it the fan rotate, SMPS is ok.
If you need more trouble shooting on SMPS you have to measure the volate on each wire after powering on.
More info http://www.smpspowersupply.com/connectors-pinouts.html
Oct 13, 2009 | E-Machines 230W Micro ATX Power Supply,...
My system no longer starts up. i would like to reinstall my xp .
Check the SMPS, if the SMPS fan rotates that means power +12V is OK, if not probably you need to repair the SMPS, let me know the symptoms
Oct 08, 2009 | ZT Group CISNET A7050 PC Desktop
SMPS Fan not rotating fully
you can check that how much time you spent with the SMPS if it is more then 2-3 years then change it because it is damaged in 2-3 years and after changing then also not work then you go to mechanic and checked your motherboar
Jun 29, 2009 | HP Computers & Internet
Color Printer fan error
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Mar 25, 2008 | Samsung CLP-600N Laser Printer
Computers & Internet Logo
949 people viewed this question
David Payne
David Payne
