Several sir/mam. What do you have?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Fatal Error - Code: 2AH
Fatal error code 2AH: Faulty memory data.
1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
3 - Change PWB-A. (8314139-0101-15)
4 - Change Parameter Chip.
hope it helps
regards
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
SOURCE: minolta 1400 pagepro there is no drivers for
please help me to connect my kodak esp printer.
SOURCE: is there a win 7 driver for pagepro 1400W?
Yes, direct from minolta http://www.konicaminolta.co.uk/business-solutions/support/download-center.html
