Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Porter cable compressor will not restart once it is under pressur
Once my compressor reaches the cut off pressure and I use a tool with it, when it tries to restart to rebuild pressure, it will not start and blows the electric breaker. I need to know what part to replace. Is there a capasiter or another swith that helps it restart?
    President:
  • 1,489 Answers
This is likely a bad check valve which is allowing pressure from the tank to leak thru back to the compressor. The compressor won't start because the compressor cylinder has air pressure on it.
The check valve is about the size and shape of a .410 shotgun shell -- it's in the copper line from the compressor to the tank.
Posted on May 27, 2009
I have a porter cable air compressor that won't shut off moble # cf2600
Sound like the pressure switch is not working. try ad lower (CCW)
on pressure switch it may be set too high. Bostitch,Porter Cable150 psig is pretty ******* compressor, I like 125 psig. Pressure Switch #DWB-N003307SV. I would look on E bay.
Apr 09, 2017 | Porter Cable Air Tools & Compressors
I have a porter cable 6 gallon compressor. The motor used to cut out at 150 psi, but now it cuts out at 135. Is this a faulty tank pressure gauge misreading the pressure or a motor cutting out too early
it could be your air pressure adjustment knob, where your air line hooks up, which controls the psi to a lower or highist seting to adjust for different tools and uses.
Aug 26, 2012 | Porter Cable C2002 6 Gallon 2 Compressor
Why my air compressor want shut off after building up pressure
If it is building up to the full rated pressure and there are no air leaks in the hoses then it is most likely the pressure switch. It is item 111 in this parts diagram.
Porter Cable C2002 diagram
Aug 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
My compressor will start and run well but when it turns off it will turn but not run stalls and kicks the breaker
It sounds like the small valve that releases the pressure out of the main pipe that runs between the compressor and tank is not working once the tank is full and the motor automatically cuts off. You know this valve is working by the sound of a short spurt if air being released when the motor cuts off. Releasing this pressure means that the motor is able to restart easily because there is no load. If the valve is not releasing this air, the compressor is trying to start under full load which the motor is not capable of doing, hence the humming and popping of breakers due to a current overload as the motor tries to start. Motor burnout is possible if it keeps recurring.
This small release valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it or is incorporated inside the Pressure Control Switch.
Sep 17, 2010 | Porter Cable Cable 20 Gal 150PSI Oil Lube...
My porter cable air compressor won't shut off when it reaches max psi, this is the 2nd compressor I've had this problem with of the same type after about a year of use.
The airr pressure cut off switch is not working or out of alignment. What you can do is to adjust the spring with the air pressure reading at your required pressure. Once this is done allow the air to flow so that the compressor will work again to cur off, you will have to trim once again to set it to the correct condition. If the spring assembly is not working well on pressure you can remove and reset. If the contact are dirty , the switch on may not start the compressor, in such case clean the contacts. But if you think that it is not acting responsive, the please replace the unit and do the settting as explained above.
I hope you try this out. Good day
Aug 16, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Pressure switch dows not shut off motor when
Pressure switch has gone bad and needs to be replaced. Part runs around $25. Go online and put in model number, pressure switch. You will find companies that sell replacement parts. I had to replace mind, it did the same thing.
May 03, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Once compressor reaches 125 lbs. pressure, the relief valve opens and releases pressure. the motor then tries to engage but cannot come to full speed because of back pressure I am trying to find and...
Generally, the safety/relief is set to 140 to 160psi. The pressure setting is stamped on the side of the valve. Replace the valve if it will not hold stamped pressure(cost about $6 at Lowes Lumber).The pressure switch is usually set at the factory to 120 - 130 psi. The unloader part of the pressure switch will not release backpressure unless it reaches set cut-off. The 1/4 inch line attached to the pressure switch connects to air discharge tube at the intank checkvalve (brass valve). The safety valve should very rarely release pressure, only when pressure switch malfunctions and allows pressure to reach up to 160psi. The tank will hold over 300psi so dont worry about the 160psi safety. I am not sure about your exact model number or brand, however most small compressors work the same and share similar parts. For manuals to other similar compessors to to www.dewalt.com. Here you will find manuals to dewalt and porter cable compressors. I prefer to use generic replacement parts from www.grainger.com or from Lowes Lumber. These parts will cost less than factory replacement. If you need to replace the pressure switch, use SquareD brand from grainger. Watch fitting sizes and pressure range. Good Luck on your repair.
Apr 03, 2009 | Northern Industrial 2 Hp Twin Tank...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
190 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
