Question about Dometic Rooftop RV Air Conditioner
Air conditioner will come on- fan motor is working- it sounds real low- it was on and then it shut off- waited a good 15 min. and cut it back on- it then started this problem
Air Conditioner comes on but it sounds weak like the fan is on but the compressor does not kick on
    Problem Solver:
  • 6 Answers
Need more info. Is the fan actually on full force or does it feel like the air flow is restricted (could be dirty coil or filter)
Is the fan on full force but only warm air coming out (compressor not working)
Is the fan on but only cool not cold air coming out (freon leak)
The more info you give the easiest it is to troubleshoot from here.
hope this help
Benge007
Posted on May 27, 2009
How do you check a fan motor
You need to check the volts at the motor while it's running, to make sure some safety is not shutting it off. Then check the amps on the motor while it's running. Also you need to check your capacitor and wiring.
Apr 30, 2014 | Heating & Cooling
We turned on our a/c unit and the fan outside came on but only for about 15 minutes and then stopped. We cut it off and waited for a little while and cut it back on and it did the same thing. We replaced...
When it cuts off, there is still power to the fan motor then replace the motor...you can check for power going to the fan right in the electrical box of the condenser...
My idea of this would be that the motor gets hot and then cuts out, or the bearing seize up when hot...
heatman101
Apr 27, 2011 | Goodman CKL30AR30 Air Conditioner
My colman rooftop ac unit shuts off after 5 min of use wait 5 more and you can turn it back on again when its running it works great its on a 1984 holiday rambler and has very low hours?
Try a new fan motor. It runs about $125.00, It will run a few min. then will trip the motor themal switch. you can probably still here the compressor running. It may also trip the breaker on shore power . good luck! the part you are looking for is a 1/3 hp 115vac 2 speed 1580/1020 rpm part number #1468-3069
Aug 25, 2010 | Coleman Mach III Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
My outside unit runs a little while then shuts off.
More likely the out door fan motor has bad bearings and that would cause the out door unit to run for 15 to 20 min but it could be low on freon
when the out door unit runs after 3 to 5 min the larger of the two copper lines going into the unit should be ice cold
If the thermostat you just installed has a time delay that will keep the indoor blower motor running for up to 5 min after the unit shuts off
Sep 01, 2009 | Honeywell Heating & Cooling
Fan would not run , so i diconected the breaker on the ouside of the house waited aprox. 15 mins. and pluged it back in. the fan tried to start and it did with alittle assist but ran backwards has anybody...
Sounds like te start capacitor is defective turn power off and mark the wires exactly like they are on the capacitor. Some capacitors are dual meaning they start the compressor and fan together. But if the fan side is bad it will try to start and after too many attempts will damage the fan motor. Let me know if I am helpful or if you need more assistance. Sea Breeze
Jul 11, 2009 | Goodman CKL24AR24 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
250 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
