Question about Toshiba Satellite P35-S611 Notebook
Troubleshooting Toshiba Satellite P35-S611
My satellite P35-S611 will not run on AC power nor will it charge
the battery
  • 4 more comments
  • VIlprofile78 Nov 18, 2007
    I am having the same problem, the ac adapter will not power my laptop nor charge the battery while the laptop is on, but the power led is on, when I turn off the computer and remove the ac adapter and re-instert it charges the battery then, but when trying to turn on the computer it goes back to battery power and will not use the ac adapter nor will it charge the battery, need some help plssss???
  • T Hefner Dec 29, 2007
    Toshiba P35 fails to charge battery or run off of power supply. I've switched batteries. No help. Charge light goes on when computer is off. Power supply jack seems to have some intermittent connection but it isn't consistent. Sometimes, the charge light goes on when manipulating the power supply cord into the jack (wiggling it). I suspect that the internal connections to the jack may be the problem or possibly the power supply output cord (butI doubt this). Any instructions on dismantling the computer to observe the internal power supply input jack connections
    Thanks,
    Bengui
    Toshiba P35 fails to charge battery or run off of power supply. It will
    operate a very short while after charging the battery with the computer
    off. Then it will go into hibernation. I've switched batteries. No
    Thanks,
    Bengui
  • tolson88 Nov 16, 2008
    I have the same exact problem outlined by the previous users.
    What was the fix?
  • richelle75 Nov 29, 2008
    We had the same problem with ours and a neighbor of ours with another Toshiba had it happen as well.  We took it in because it was still under warranty and they replaced the jack and it worked for a couple months then started doing the same thing again, so we took it in again. We got a new computer the third time.
  • Anonymous Feb 10, 2009
    I am having the same problem, the ac adapter will not power my laptopnor charge the battery while the laptop is on, but the power led is on,when I turn off the computer and remove the ac adapter and re-instertit charges the battery then, but when trying to turn on the computer itgoes back to battery power and will not use the ac adapter nor will itcharge the battery, need some help plssss???
  • 4,889 Answers
This can be due to 3 reasons.Check these out and report back so that i can help you out
1.The AC power cord is damaged:Try connecting another chord to see if its the problem is with this
2.Damaged Battery
3.This is slightly tougher..you will need to open your laptop check if the DC powerjack is damaged..If you dont know how to check this come back and ask..I will guide you
Posted on Oct 21, 2007
    Genius:
  • 1,601 Answers
Bad power supply???
SOURCE:
Bios password locked toshiba satellite m30-s350
you can try software flashing or removing cmos battery, here you must be familier with hardware fixing else take it to apro
Oct 27, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
http://www.google.com/products?q=Satellite+A75-S206+battery&hl=en
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1501060
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
P35 Shuts down
Go into Toshiba Power Saver in Control Panel and set Processing Speed and Cooling Method to midrange. You will not have the problem anymore.
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite laptop Model 035 S611
If it is completely frozen press and hold the power button (you will lose any unsaved work) it should turn off, failing that remove the power source.
May 18, 2008 | Toshiba Satellite P35-S611 Notebook
My Satellite P35-S611 will not run on ac power nor will it charge the battery
this happened to me also after window update ..i think it was updating with sp3
Feb 02, 2008 | Toshiba Satellite P35-S611 Notebook
My satellite P35-S611 will not run on AC power nor will it charge the battery
I have just fixed the same problem on my Toshiba p35 s611.
The power jack inside the laptop had been damaged. To reach the problem you must take apart the entire laptop (there are a few guides for doing this online). Next I simply found the positive connection coming from the jack (it is the wire coming out of the back of the jack) and followed it to where it enters the motherboard. I simply flipped it around and re-soldered that one spot. Other sites recommended I remove the jack but I couldn't melt the solder enough to do so, however just trying and adding some fresh solder was enough to fix the problem. I no longer need to jiggle the power connector to the right angle just to get power.
Toshiba Satellite P35-S611 Notebook Logo
384 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
