Question about Epson Stylus Pro 10000 InkJet Printer
00030017 i replaced the magenta ink cartridge and i still get this error can you help?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Check the cartridge very well .... make sure it is the original... i mean the recommended cartridge for the printer.... sometimes, refill cartridges gives problems..
thanks for the question
Posted on May 27, 2009
26.001 error hp 4000
26.0:01 is a bad contact in the Ink Supply System for the yellow ink cartridge. (This can be caused by using non HP OEM ink)
Check that the ISS to Cartridge cable is not damaged and is fully connected to the Ink Supply Tubes PCA.
You can also try switching the magenta contacts with the yellow contacts and see if the problem stays with the yellow, or you now have a magenta problem.
If the problem stays with the yellow, then you will need to replace the Ink Supply Tubes and Trailing Cable.
If the problem moves to the magenta, then you just need to repair or replace the contacts (may just need cleaned)
Good luck !
(My money is on bad compatible or refilled yellow ink cartridges)
Apr 12, 2013 | HP Designjet 4500ps InkJet Printer
Cartridge Error - Interference with magenta communication
check under the ink cartridge there is a seal it is probably missing look at the other ones you'll see the seal but on that one it will be missing
Oct 23, 2012 | Lexmark Interact S605 All-in-One Color...
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
Epson 10000 service required?
Hopefully you already have this solved. I had this happen on mine just this last week. The error itself is that the ink level sensor (not the cartridge, but the head) does not detect the correct level of ink. 00030017 is for Magenta specifically. The first step would to make certain there is actually ink in the Magenta cartridge. Physically remove it from the printer and give it a little shake to be sure there is ink in it. Mine had stuck on a nozzle check error and completely exhausted the cartridge.
Dec 01, 2009 | Epson Stylus Pro 10000 InkJet Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Epson CX 5400 won't recognize off brand magenta cartridge
Yes replace the possibly faulty cartridge as some just don't work. If you take it back to where you bought it from they may replace it with annother one free of charge?
Hope this helps....
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Brother mfc-410cn colour cartridge problem
There may be three problems here.
1.Not doubting your skills for one minute, nor wishing to offend you in any way, but did you remove the protection strip off of the Magenta ink cartridge? Sometimes we forget to do that.
2.Once a new ink catridge is installed, it's best to go to the Brother diagnostic tools section, and run a test. Sometimes an error code is kept, (Ink cartridge is empty), and the diagnostic tool checks this out. It then clears the error code, and 'recognizes' the new ink cartridge.
3.Ink may have dried, for the tiny little holes for the magenta ink cartridge, where it attaches to the body of the printer. Just this one ink cartridge. Suggest you don a pair of rubber dishwashing gloves. MFC-410cn -> Unplugged <- from the surge protector, use a clean, lint free, warm water, damp cloth, and wipe the holes for the ink cartridge, where it lines up with the printer body. This will be where you see that copper metal strip. (Or perhaps it's brass)
To clarify, you are cleaning the printer body. The area where the ink cartridge goes, and the metal strip. The ink passes from the ink cartridge, and goes through holes in the body of the printer. The metal strip is where these holes are located. Allow this area to dry. You may want to use a hair dryer set on low heat to speed the drying process up. Constantly move the hair dryer back and forth. Keep it about a finger length away.
Once you are satisfied this are is dry, reinsert the magenta ink cartridge. Plug the printer back into power. Advise waiting one minute, then turn the printer on.
Use the Brother diagnostic tool.
Should you not be able to find the Brother diagnostic tool, I suggest you go to Start>Hover your mouse cursor on All Programs>Go over to Brother>MFC-410cn>and to the Help section. The Help section, will tell you how to open the diagnostic tool.
Aug 19, 2008 | Brother MFC-410CN All-In-One InkJet...
My canon pixma i4300 is telling me that an ink cartridge needs to be replaced- I open the cover and the magenta cartridge is blinking- so I uninstall it - it is full of ink - I reinstall it it stops...
My canon pixma i4300 is telling me that an ink cartridge needs to be replaced- I open the cover and the magenta cartridge is blinking- so I uninstall it - it is full of ink - I reinstall it it stops blinking but the minute I put the cover back down I get the same error- Whatsup?
Aug 07, 2008 | Office Equipment & Supplies
I have error 29 on my 210c
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
Nov 14, 2007 | Brother MFC 210C All-In-One InkJet Printer
Epson Stylus Pro 10000 InkJet Printer Logo
416 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
