Question about Panasonic Lumix DMC-LS80 Digital Camera
Locked memory card
When i turn on camera, i get a message that says..memory card is locked. how can i unlock this, and how did this happen.
  • demops May 27, 2009
    Killabyte you are a gem...thanks heaps.. :]
  • 18 Answers
This must be an SD card. To the left of the card is a little button that says lock and with an arrow pointing down (if i remember correctly). Just slide the button the opposite way and your good to go.
Posted on May 27, 2009
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
Get card locked message when I turn camera on. Can't turn the message off,\.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 14, 2012 | Samsung SL35 Digital Camera
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Camera turned on. go to take a pic. nothing happens and 'card locked' comes up on screen
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Jun 28, 2011 | Cameras
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. How do i fix this?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Oct 09, 2010 | Sony Cybershot DSCW310 Digital Camera
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Locked card
Pull out your memory card, and find the little gray slide switch, if it is away from card connection it is locked, slide switch (little gray slide switch) toward the card connection. This will unlock your memory card.
Nov 06, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Memory card is protected how do i switch on memory card when i turn camera on, message reads that the memory card is protected and to reset switch on memory card. what happened?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 11, 2008 | Kodak EasyShare CX7330 Digital Camera
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Panasonic Lumix DMC-LS80 Digital Camera Logo
115 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
