Question about iLO 3200 32 in. LCD Television
I have an ILO 32Inch LCD TV and it keeps shutting itself off but only if I'm using something hooked up to the HDMI output or the component output I think it is (the one with the blue and green colored cables) when it's on the AV ouput it works fine. Please help!
  • knockonthesk May 27, 2009
    How do I do that exactly?
  • 744 Answers
Hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
Posted on May 27, 2009
  • Prakash Ram
    Prakash Ram May 27, 2009
    if u have a knowledge about a television u can do this.. but if u dont have any idea about it try to do with the help of a tv technician.. because if u try to do alone and if u are unable to do means the cost will lead more.. its better to hire a tv technician and aks him to check for transistor connections. he will do it perfectly...
    thank u..
WELL???? PDP4210EA hooking up to it?
I was able to find a service manual online which lists the inputs for that TV as the following:
  • RF connector (cable/antenna)
  • Composite (yellow video, red/white audio)
  • S-Video
  • Component (red/green/blue video, red/white audio)
  • D-Sub (analog PC connector)
  • DVI (digital PC connector)
Your Playstation would need to be plugged into either the component or composite connectors depending on which Playstation you have. The Playstation 1, Playstation 2, and Playstation 3 all can use the same composite cable, and the Playstation 2 and Playstation 3 can both use the same component cable. The Playstation 4 only uses HDMI, which your TV doesn't support, so you would need to use an HDMI to component converter (under $20 on Amazon).
As for the Roku, same rules apply, but it again depends on your Roku model.
Oct 24, 2017 | iLO Televison & Video
My ilo has no hdmi port so how do I hook up ps3to my TV
You can use the old ps2 video connector with the yellow red white. Or rgb red green blue with wht /red audio for 720, or they make HDMI converter boxes for HDMI to other outputs.
Sep 12, 2015 | iLO Televison & Video
I have an ILO - 32HD Television but the cable cord that comes from the wall does not have a place on the TV to connect to. There is an indentation labeled ANT in the shape of a USB port which it isn't,...
Your TV comes with HDMI, DVI, Component In and S video in. Since it has no Tuner built in you will have to use a Set Top box with either component out or if you buy an HD Set Top box with HDMI out. The later will be in your favor so that you can use the only component video input for your old DVD player and not keep juggling pins at the back
Mar 07, 2011 | iLO 3200 32 in. LCD Television
I have a 32inch Phillips HD ready TV but there does not seem to be and HD input for my DVD player
"HD input" is HDMI. If the DVD doesn't have HDMI output then use the 5 wire hookup - the component hookup.
The TV input for HD would be HDMI or component input - 5 wires.
Nov 25, 2009 | Philips DVR-1
Lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Mar 07, 2009 | Samsung LN32A330 32 in. LCD TV
32inch ILO LCD ...Shutting off
It looks like the power supply is failing on your TV. Some of the components are starting to fail after the TV warn up.
You can try contacting the manufacturers and ask them if they could Honor the 1 year manufacturers warranty by giving them the model and serial number, or hopefully the can repair by taking the date when the TV was manufactured.
I service these power supplies.
Let me know if you need further assistance. my email is jah2mil@hotmail.com
May 17, 2008 | iLO 3200 32 in. LCD Television
32 ilo lcd
most boxes have component out or HDMI connection use either one and cable box or satelite came with instruccion on how to connect it ..
Mar 30, 2008 | iLO LCT32HA36 Television
ILO 32inch TV
ILO 32" lcd hdmi tech support Eastern Time
8:30 am - 9:00 pm (monday through friday)
9:00 am - 5:00 pm (saturday)
1-800-428-1105
my 8 month old tv doesnt even turn blue. just blinking red light where on/off light display appears. very discouraged cause wallmart will not help. trying techsupport. i found this number from my purchase paperwork. hope it is helpfull to you.
Dec 10, 2007 | iLO 3200 32 in. LCD Television
What part or adaptor do i need
for basic cable you will need a cable tuner with either component, svideo, or hdmi outputs. most cable companies will provide these for free or for a nominal fee.
hope this helps,
trin
Nov 17, 2007 | iLO 3200 32 in. LCD Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
iLO 3200 32 in. LCD Television Logo
46 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
