Question about Panasonic Lands Phones
Panasonic phone KX-TGA710CX - Analog/Digital dialing
I have a cordless Panasonic phone KX-TGA710CX, and somehow it changes to dial in an analog mode and not digital mode, which means I cannot use it to call any automatic operator.Can't find the right button to press in order to change it again.Can you please help me?
What is the recommended battery put in the panasonic kx-tga710cx?can i put ordinary battery or rechargeable battery?
Posted on Feb 07, 2010
I bought five Panasonic KX-T7730X phones. The business i work for has a Panasonic KX-TD1232 system. I unpack all phones and tried it on different extensions and won't work. there isn't ant pulse....
A TD system is a DIGITAL phone system and the 7730 phones are ANALOG. I don't know what X means, but I guess they're not from the US :-). Anyway, the ANALOG phones need 4 wires to work, instead of the 2 that the digital phones have. If your installer was lazy and didn't cross-connect 4 wires at the frame or put in 4 bridge clips on each jumper, then you don't have a voice path. Or, XDP is turned on and you'll have a bit of a problem.
If you have an IM and a PM for the TD system, you can find the wiring diagram and the instructions to read the XDP status. Quick answer is the first 2 of every 3 pairs will run to your phone. If you start with a digital phone in the port first, turn on XDP and plug a single line set into the XDP port, you will get dial tone (may have to dial 390 or 391 to enable/disable the XDP twinning) and that dial done will be different from the digital phone. If you don't get dial tone, your first pair wiring is missing. Fix that, turn off XDP and you 77xx series phone will now work in the port.
Carl
Jun 23, 2011 | Panasonic KX-T7730 Corded Phone
How do I use the intercom function on a KX-T7731 phone??
Panasonic analog phones plug into analog KSU's and have extension numbers beginning with 101. In additon, you can dial 0 to reach the phone programmed as Operator, and it's usually extension 101.
With the intercom dial tone (press INTERCOM or pick up the handset or press SP PHONE) you can start dialing codes defined in your number plan. You can also program left side buttons to monitor are directly select other extensions or dial codes to page all idle speakers in a 77xx phone.
Note this is specific to TA series systems, but the operation is similar in all Panasonic models.
Carl
Apr 19, 2011 | Panasonic KX-T7731 Corded Phone
Have a kxt-7453 and need to attach a heart monitor which needs an analog phone line. On the back of the kx-t7453 is an XDP jack to attach a fax machine. This would be the analog port; however, there is...
It depends on the system the phone is wired to. A TD-816 has modular plugs on the base cabinet, but uses an Amphenol cable for the expansion units, and a 1232 is all Amp. You need 4 wires to make it work. The quickest way to test is is to unplug the digital phone and plug a single line set into the same jack. If it works, then you need to do some system programming. If it doesn't some wiring.
The digital phone uses the outer paris of a 4-conductor jack, and the analog/XDP is on the inner pairs. We always use 2-pair jumper wire on TD systems, but some installers cheat and don't wire both pairs. You'll know if it works because the single line phone you plug into the jack alone will have the same extension number as the digital set.
If you have dial tone there, by default, when you plug in the digital set, the XDP has to be turned on in program 600 and there's a merge/unmerge comand. The XDP port is 100 more than the station (ie 103/203) and the code to merge/unmerge is 390 and 391 (I can't remember which, so look at the display as one merges (probably 1 and one doesn't 0)
You'll have to teach the device to dial "9" or an access code 81-88 to get a specific line or group.
Outside of that, it's not that bad to program.
Carl
Sep 18, 2010 | Panasonic KX T7436 Corded Phone KX-T7436
I have a phone system in my house using the KX-T7633 model corded phones. I want to plug in a cordless phone in the back of the KX-T7633 so that I can be cordless, but when I do I can not get a dial tone...
In a TDA-30/50 there are FOUR super hybrid ports, the first 4 on the cabinet. In a TDA 100/200/600, there are NONE. Which one do you have and is your extension 101-104? If not, it won't work. You can probably wire an analog port to the first pair and use the same cable, but it will never merge with the digital set.
Carl
Aug 24, 2010 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
Is panasonic KXTG5432 an analog or digital phone?
It doesn't matter. The recorder is on the landline side of the system. If you are being harrassed via telephone contact your provider. It is an offence in most countries in the world. They will help you resolve it a lot quicker and can block the calls from that caller.
Oct 24, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
Analog card not working in tda100
you will still need to dial a 9 from the phone to get an outside line, or you can program the analog ext to auto dial it for you. If you still can't then it sounds like the phone is in the wrong COS so it doesn't have access to the CO's.
Apr 15, 2009 | Panasonic (KX-TDA0104) (KXTDA0104) Power...
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
Dialing mode option change.
Program --> Auto --> ** --> Program (Pulse to DTMF)
Program --> Auto --> ## --> Program (DTMF to Pulse)
Jul 30, 2007 | Panasonic KX-TGA101S Cordless Handset
Lands Phones Logo
513 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
