Question about Maytag MER5770 Electric Kitchen Range
Error Code F-9
Maytag range giving F-9 error code
    Problem Solver:
  • 5 Answers
You can fix this problem by just cleaning the ribbon cable.Never use the self clean.
Posted on May 27, 2009
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
You are in Jewish Sabbath Mode, it is 'Sab'
Search Results Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab". To disable the Sabbath mode push and hold the Clock pad for 3 seconds.Nov 10, 2007
Maytag Oven WEIRD Error Code 5ab - Appliance Repair Forum
forum.appliancepartspros.com/oven.../2348-maytag-oven-weird-error-code-5ab.html Feedback
About this result
Will you tell me what error code 5A6 means on Maytag MGR6875ADQ ...
https://www.shopyourway.com/questions/1098960 Nov 24, 2010 - As indicated in the previous response, the 5A6 indicates that the range is in the Sabbath mode (SAb). The image below shows the information on this mode for your range. Press the CLOCK button and hold it for 3 deliberate seconds to cancel this Sabbath mode. The control should then work normally. what does the f-2 error code on my maytag oven mean?
26 Jun 2010
What does the SAB error code mean on my Maytag ...
1 answer
1 Jan 2010
How do I cancel the Sabbath mode on my Maytag range?
30 Dec 2008
What does an SA6 (or 5A6) error code mean on my ...
1 answer
13 Nov 2008
More results from www.shopyourway.com
Maytag Oven SAb error code - YouTube
? 0:54
https://www.youtube.com/watch?v=XUP1BOzqPUo Jan 1, 2014 - Uploaded by Life With Christ
The SAb error code will freeze your oven functionality and you will not be able to cook or program the oven ... Oven Repair including Ranges and Cooktops
Mar 12, 2018 | Kitchen Ranges
Repair man fixed top oven probe sensor due to a F1-1 error code. Top oven is still giving the same error code. Repairman wants to come back and charge 200.00 bucks again to replace bottom oven sensor.
The electronic control could have a bad touch pad that is causing this. You may need to replace the electronic control itelf. It is expensive almost 400.00 dollars.
Nov 20, 2014 | Maytag Gemini 30" Self-Cleaning...
Will not get hot
Thank you for submitting your question. The error code is indicating a outlet mis-wiring issue or control board issue. If the unit has been working fine then it will be the control board.
Here is the part to order.
Whirlpool W10476673 Cntrl Elec AppliancePartsPros com
Apr 06, 2014 | Maytag MER7664XS 30" Freestanding Electric...
Display codes
what kind of oven and model, run this on a computer, just put it in the browser, i can run it for you but need the type, maytag or other ect. Matt
Oct 29, 2017 | Maytag MER6772BAS Gemini Electric Kitchen...
Error code -SE-
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 17, 2011 | Maytag Over-the-Range Microwave
Maytag, advanced cooking system , super capacity, error code f9
A model number would help, but an F-9 code is usually followed by a 1, 2 or 3.
F-9-1 is the board is not seeing the door lock
F-9-2 is the board not seeing the door unlock
F-9-3 is the board seeing both inputs and not knowing the condition of the door lock.
The problem is like caused by a failed switch in the door lock mechanism. This normally requires the replacement of the door lock assembly.
Nov 22, 2010 | Maytag Kitchen Ranges
Getting error code 9-6 on MER6770AAW maytag gemini double oven range...what and how to fix?
That code is for obstruction in the lower door lock mechanism. You need to check for a obstruction in the lower door lock. The next step would be to disconnect the power for a few minutes then turn it back on and see if the code reappears.
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag range fault code F92
There should be some number after the F 9 Error code. And, it would look like this
F9-1 Latch lock upper
F9-2 Latch unlock upper
F9-3 Latch lock lower
F9-5 Latch unlock lower
F9-6 Latch both lower
This is just to give you an idea. But one thing you can try is UNPLUG THE UNIT AND LEAVE IT LIKE THAT FOR AN HOUR OR TWO, AND THEN PLUG IT BACK IN.
Jan 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5770 Electric Kitchen Range Logo
265 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
