Question about RCA Televison & Video
Tape goes in but then pops back out
The tape goes in all the way but then pops back out
  • 458 Answers
This is because the tape carriage is not able to take the tape fully into the threaded position. If you have young children in the house, remove the lid & check that there are no "objects" inside. If not, then the deck mechanism is possibly out of alignment & would need to be repaired.
Posted on May 27, 2009
I put my tape in it only goes down 1/8" sits
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Nov 12, 2010 | Canon XL1S Mini DV Digital Camcorder
I have a Sony Video8 Handycam CCD-FX340 NTSC. It will not accept a tape. I can hit the eject button and the tape mechanism will come up and pop open. If I close it without a tape, it will go back down....
This problem can be caused by condensation. Leave camera and tapes in a warm dry place for a day and try again. If that doesn't help, there may be a tape threading fault. This can be something as simple as a broken drive belt, but still will require professional attention.
Oct 28, 2010 | Sony Video Cameras
Tape is stuck and will not pop out. I get error E01
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined and I don't recommend using the tape in the camera again even if you manually wind it forward past the problem area.
May 20, 2009 | JVC GR-D770 Camcorder
Dell dat 72 drive will not accept a tape
power off and on the tape drive
Inset a NEW Fresh out the Wrapper cleaning tape and see if that works!
Sounds to me like your existing cleaning tape has expired
If that fails then there could be a problem with the loading mech which is where you will need to send it away for repair.
Try www.tape-drive-repair.com for this as they are not expensive
Dec 09, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Vcr tape stuck in unit
Marvin,
I am not registered here as an expert, so there should not be any charges. I do not have the option of chatting I am guessing only the registered experts have that. Here goes: 1. Take a phillips screw driver and remove all the screws that are holding the case on, there will be some big ones on the sides and a few maybe smaller ones on the back. 2. Lift the the case off 3. You should see the tape on the inside the vcr 4. You may or may not have to remove some of the metalic shielding which should be only anywhere from 4-6 screws if you have a piece of metal directly over the vcr tape some have them some do not. 5 Gently pull the magnetic tape up from around the feeder posts and the drum. 6. Try and work the vcr tape up and out, If you are having extreme difficulties with this try plugging the vcr back up and pushing the eject button while still holding the magnetic tape. The tape should eject now and you and carefully pull it out. 7. When you get the tape out, use your thumb to push up and turn one side of the white reals on the tape to slowly wind the magnetic tape back inside the tape. 8. Unplug the vcr again and replace everything that you had to remove and replace the cover.
I hope this helps and let me know if you need further assistance. And since I am not a registered expert here there should be no charge for this help unless you chatted or got help from one of the registered experts.
Jul 05, 2008 | Samsung DVD-V5500 DVD Player/VCR
Canon zr20
Try toggling the opening hatch, tricking the machine into thinking it's being opened and closed...
May 24, 2008 | Canon ZR20 Mini DV Digital Camcorder
I cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Feb 25, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
TAPE COMPARTMENT KEEPS POPPING OPEN
I Had The Same Issue And Fixed It :o) I Have A Sony Handycam CCD F-730A 8mm. I put the tape in and close it but it would not load the tape down. It just pop back out. If I took the tape out, it works perfectly and would loaded the tape doc down and close.
1st: I unscrewed and removed the door to the tape. Where the tape can be seen. 2 screws hold it down. Without the tape inside. I Saw a Clear Small Plastic in the inside of the camera where the tape sits on each side. On Both Sides, Left and Right are clear plastic like sensors. They look Like Glass and are small.
2nd: I Cleaned them both with a Q-tip and rubbing alcohol. It Worked. The tape loaded and worked nicely.
It was strange. If i touched one of the small glass like sensors. the mechanism the loede the tape would not work. When The Glass sensor was blocked by the tape or just by my finger in front of it, it would not load. Very strange.
Bluelikealex :o)
Oct 31, 2007 | Video Cameras
Cannot get Tape to into camcorder
Have you tried using the cleaning tape ?
Jun 02, 2017 | Sony Handycam CCD-TRV107E Camcorder
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
