I try to copy a picture and press start. Everything sounds normal except the paper doesn't feed. Help.
  • walleye706 May 27, 2009
    There was no paper stuck, what now?
    thanks
  • 202 Answers
The first thing to do is power cycle it, perhaps its hung up a bit, and needs to be reset. Next, make sure the paper is loaded in the hopper correctly (not that there's an incorrect way to do it, but you gotta advise on this stuff).
If there is a paper feed button, press it while trying to put a page into it.
Also if you can provide a specific make/model, that may help the next person if this doesn't correct your issue)
Hope this helps
Chris
Posted on May 27, 2009
  • 952 Answers
Try to check the paper feeder... is possible that stuff got stuck inside.. this will stop the paper from feeding...
When i press start button on my Canon Gp225, it doesnt respond.. it dont even give any error msg also.. i tried loading more papers n closed the paper tray properly also.. tht gives proper sound also.. but...
if the start button doesn't responds could be that the microswitch/contact of start button needs to be cleaned/resoldered/changed.
You can try to apply small ammount of wd40 on the edge of start button. In some cases helps as first aid.
Call service!
Hope that helps!!!
Aug 29, 2011 | Office Equipment & Supplies
When I try to make a copy the error code P flashes and paper in unit jams but I can still make copies thru bypass
P error normally indicates that you need to add paper. If there is paper in the cassette and the paper is raising up to the roller then the paper feed rollers are most likely dirty. You can clean the rollers with a cloth and some rubbing alchol. Also make sure you dont have a small peice of paper or something in the paper path causing the paper not to feed. Also listen when you press the prnt/start button and see if you can hear the paper feed clutch turning on then the paper feed rollers turning.
Jan 16, 2011 | Office Equipment & Supplies
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper Jamming when trying to copy or print
please check after you load paper on the paper tray and push it into the machine, should hear a click sound, if you don't hear that sound, that means you need to buy a new printer and that's no way to fix.
If you are able to hear a click, then please try to clean up your printer and check all paper loading rolls. if so, please replace it.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Front Paper Feed Issue
Based on your description of what's happening, especially the part about the paper sometimes skewing or jamming from the back also, it sounds like there may be a small piece of paper caught back there in the roller/feed area. You may want to try feeding a piece of heavy paper through, try from the top/back first, and see if it will push whatever may be stuck in there out.
Also, try opening the door on the back and use a strong light to see if you can see anything in there. Be careful if you try to remove anything, not to pry against the rollers or feed mechanism. Maybe use a long tweezers.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
jasbo
jasbo
