Question about AOpen MX4GVR INTEL 845GV Motherboard
Usb port in my mx4gvr
The USB Port dont work in my motherboard mx4gvr
  • May 11, 2010
    Do any of the USB ports work? This board has both rear panel USB connectors built onto the board and headers for cables to USB connectors on the case. Are they all non-functional?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 27 Answers
Did they work earlier?
if so then it might have something to do with youre registry or drivers
This might help
http://www.ntcompatible.com/Desperately_need_help_---_USB_Devices_Not_Recognized_t32356.html
Posted on May 27, 2009
My usb port wont work.i dont know why?
Install the correct drivers and make sure the ports are correctly connected to the mainboard.
May 04, 2013 | Computers & Internet
My front usb port on my pc are not working and how to fix it
If she shorted out the usb ports then you would want to replace the motherboard.
Dec 24, 2012 | Nvidia Ecs Mcp61m-m3 Geforce 6150se Socket...
Usb header not working
Usb ports are bogus. You can always install a pci usb card though. Beats replacing the mo bo since you have already tried everything else to no avail.
Apr 15, 2017 | ASUS M2N-MX SE Motherboard
My compaq G60 laptop dont have ethernet lan driver how i can solve this.
buy a adaptor callled "USB LAN adaptor" ....connect to ur USB port and then connect the LAN cable to that adaptor...ur USB port turns to a LAN portb67261b.jpg
Feb 02, 2010 | HP Compaq Presario F500 F700 and G6000...
Problem with USB port on Asus P5KPL-AM SE Motherboard
Older motherboards have USB 1.1 ports;
newer motherboards have USB 2.0 ports,
which are over 10 times as fast.
It is Windows (not your motherboard) that should do the "Plug-and-Play" thing for devices connected to your USB port(s).
Note that some devices are USB 2.0, and will *NOT* work when plugged-in to a USB 1.1 port.
Either get a newer motherboard, or get a PCI add-on card that adds USB 2.0 ports.
Sep 10, 2009 | ASUS P5KPL-AM SE Motherboard
USB port problems
You need the motherboard specs, which you can look up on the internet, based on the maker.
With the USB ports, the front ones often don't include power.
So plug a powered 4 port hub into the front port, and then the hub will supply the power after that.
Jun 26, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
MY PENDRIVE IS NOT GETTING DETECTED
hi im josh in cebu phils. friend if not detected the problem is you usb port or the flash disk. if you tried using your flash disk in other computer and you are sure that it is functional. then go to your usb port.check the connections.check also the confg.from the device manger if the printer port works. then dont forget that windows 98 and older versions of windows dnt automatcaly detect usb.good luck .
Feb 20, 2009 | Intel Motherboard
Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
AOpen MX4GVR INTEL 845GV Motherboard Logo
63 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
